Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
También conocido como multitester o VOM (voltímetro-ohmímetro), un multímetro es un instrumento de medición electrónico utilizado para medir voltaje, corriente y resistencia. Incluye dispositivos de prueba portátiles y de sobremesa.
Multimeter continuous beeping in continuity mode
Imagen
continuous beeping even with test leads removed.
checked battery and opened it up with no showing of corrosion or something shorting anything. Fuse still intact also did not work with high voltages.
Was checking some dead phone batteries at the time and when got back to it it kept beeping.
does not want to work in any other mode at all.
Es esta una buena pregunta?
Puntuación 9
10 comentarios
What type of model and make of Multimeter do you have?
- de
It just says Digital Multimeter DT369.
It isn't the clamp model I found when looking for a service model though.
- de
added pic of Multimeter if that helps.
- de
Hmm. That's one of those economical run-of-the-mill (but nonetheless useful, when they work) chinese meters. Well, you're going to have to buy a new one anyway if you'd want to troubleshoot this one ;)
- de
Same problem found in UT-33D giving continue beeping without probes only on Diod mode
- de
Mostrar 5 comentarios más
Agregar un comentario
13 Respuestas
Solución Elegida
I would have to agree with Flying Dutchman it's not worth putting any money in or time since you can buy a new for less but I strongly recommend fluke meters if you can they are roughed reliable and accurate. It sounds to me that the logic board is bad and needs to be replaced.
Fue útil esta respuesta?
Puntuación 2
11 comentarios:
I was looking for a somple solution to my problem since I could not find anything conclusive online. For basic troubleshooting it was handy and one not to just throw stuff out I would always look for some solution as so the same problem doesn't resurface.
Just hoped this one would last longer since it had the few extras I needed.
Much thanks.
- de
I understand, if you want I know sometimes I've had issues with other multimeters and a cheap and inexpensive way to troubleshoot is to replace the leads. It could be some bad leads that could be giving this problem.
- de
it even beeps without leads. The guy at store said this the best they have and only other was a few cheaper ones.
- de
Now, I know I'm very late and I understand that mine was working on all other modes, but here - I was using my cheap Chinese multimeter to measure voltage on an AC circuit a year ago, I was testing the continuity too like I was alternating between the two tests, at one point I mistakenly/ accidently tried to check the voltage in the circuit on the continuity mode, and then the beeping won't stop, well I was almost headed to the store to get a new one but then the beeping stopped, I checked if the multimeter was working on other modes, it was, surprisingly it was also checking the continuity but it wouldn't stop beeping, so I just tried to fix it somehow by doing deliberately making the same accident happen again and this time, it used to continue beeping but the buzzer would shut off in 20 secs or so, I then opened it up, removed the battery and placed it back in, and it started working on every mode like nothing had ever happened to it !
- de
Gee, when this happens the feeling is a mixture of frustration and joy!
- de
Mostrar 6 comentarios más
@cois Is there still functionality when reading the meter is it just the continuity .Is there continuity functionality , what reading are you getting with the leads not connected and connected, if all other functions are OK don't throw the baby out with the bath water. I agree with Flying Dutchman in that you need a multi meter to test this one . I have a drawer full of cheap multi meters (family seems to think its a good fathers day gift)and I use them all I have an expensive Snap on multi meter and I tend to use the cheap ones more often.
Puntuación 2
1 comentario:
it just shows zeros no matter to what I turn it and of course beeps in continuity mode even with leads removed.
Picking up a very cheap model today just to be able to troubleshoot some minor things. and if there is something to fix here that would be great too.
I will be investing in a multimeter in the not so near future since where I live now the only way to get quality is to ship it. Got this one because it had the thermometer function which I needed.
- de
I have a cheap Chinese multimeter UNI-T 132b and while I was unknowingly measuring currents way above 200 mA (the chosen scale) it just stopped measuring anything. The other functions worked like charm except DC small currents and diode/continuity. Similar to your situation, leads or not it kept on beeping while testing for continuity. Opened it up and found that the fuse for that circuit was gone. I temporarily 'replaced' it with some plain wire to test the multimeter for further damages. Beeping stopped and DC small currents measurement worked just fine. So that's like an error beep or something. Bought a new fuse for under a dollar and my multimeter is as good as new now. Hope you have the same luck!
Puntuación 2
I had the same problem with UNI-T 132E and the cause was a blown 500ma fuse. Easy fix :)
Puntuación 2
1 comentario:
Ya Their is a video on youtube to solve this problem.
But HereIn my meter their is no fusees in their !
Don,t what to do !
- de
I have an expensive Sumo DT-61 and it is having the same problem especially after i accidentally tested a charged 400 volts capacitor for dc voltage output of an electric mosquito bat/zapper which created a spark onto the lead probe but despite that all other tests are still working except for diode test, continuity test with never ending long beeping sound and ohm mode. My multimeter can accept up to 600 volts max for dc voltage test so I don't know why it is causing this issue. The fuses are also working and I had also changed the battery. I don't know if this is a chinese multimeter but I think that Sumo Industrial is either a british or scottish company based in Glasgow, UK and this multimeter is the most expensive one in the store since it is also an environmental multimeter that can measure noise, temperature, electromagnetic frequency and light. I think that I better RMA it.
Puntuación 1
check the fuse inside.....315mA 250V (5mm x 20mm)
less than $1
Puntuación 1
Replace 200mA fuse, Your issue will be resolved
Puntuación 1
2 comentarios:
That was first thing done. And it never worked. In end i just chucked it somewhere where all non working stuff goes and replaced it with a better model
- de
Thanks a lot....!
I had the same issue with Mastech Mas830L. I've done the stupid mistake of checking the continuity while the capacitors were still charged. I thought I might have destroyed some important component and was planning to buy a new one. After reading this I found that I jst have a blown fuse and nothing else.... It totally worked for me.... Thanks a lot again...
- de
Don’t ask why this worked, but I reversed the polarity on the battery for a second or two, and mine works properly now.
Puntuación 1
2 comentarios:
Aw !&&*, that sounds crazy enough that it might just work. It's counter intuitive but also, so obvious that it makes totally logical sense. I'm going to give it a go for myself. Nobody knows why some of these phenomena happen with a complete and accurate understanding. Although, many won't admit the truth of it. It is what it is. Sometimes you don't ask why, you just accept it.
- de
My Fluke 111 had continuity beeping permanently, tried the battery trick viola it worked. Kudos to you my man 👍
- de
I hate it for you buddy, but I thinks it’s gone. Like you, I'm not sure what is causing it to continously indicate continuity regardless of the leads even being connected or not. I think I know what caused it in the forst place though. I probably monmentarily connected to a circuit intending to measure for voltage but failed to adjust the DMM measurement settings from ohlms to voltage. It's an easy mistake to make. I have always heard that it is one of the worst things you can do to one. I must have been fresh out of luck this time. My advise to you is not what you would like to hear. Don't waist your time and money and hopes on trying your troubleshooting skills on a possible fix. If you somehow did happen to isolate the problem, attempting a fix is ultimatly going to result in failure. That sounds a bit pessimistic but, really, it's not if your goal is to minimize the negative impact of accidently frying your only DMM. Seriously though, I screwed around with mine for almost a half an hour to no avail. In that time, I basicly only was able to check out the fuses. This turned out to be just pointless and I might have realized it earlier on if only I had looked at what had happened more logically instead of mourning my lose with false hope. It’s clear that the fuses were going to be intact. The beep indicates continuity. The DMM will not indicate continuity if this fuse is open. Remove the fuse. The beeping stops, but you definatly don't have the ability to measure continuity now though. More than likely you aren't going to be able to read resistance in ohlms either. Mine reads dead short with or without leads . More than likely all the readings are going to be comptomised. I wouldn't use it for anything critical. I wouldn't just chuck it though. It could still be useful to you. Clearly lable it as defective. That way you don't accedentally continue to use it, especally if you replace it with an identical unit. Blown DMMs are a right of passage in this trade. I promise, if you continue to delve into all things elrctronic, this will not be the last time you accidentally smoke your valued testing equipment. Being tired or over worked or trying to rush will cause you to make mistakes. Always try to work with a major emphasis on safety first and alot of useless misfortune can be avoided.
Puntuación 0
Might be something simple as an smd switching diode, 1 penny part. You require a certain amount of electronics know how to troubleshoot a circuit so if you dont know what an smd component is (and you probably dont if you have no other dmm) then put it on the shelf until you become more adept at circuit troubleshooting.
I have about 300 multimeters last count but hey thats my forte
Puntuación 0
1 comentario:
You dont have to be a dick about ut
- de
It's the fuse.
Get a 5x20mm BP/GMA 500mA 250v
Procedure:
- Remove battery screw and cover
(PH1 Phillips)
- Remove 4 backing screws
(2 under the "AAA" batteries & 2 in top back)
- Gently pull apart in half @ seam
(Careful to not pull battery wires)
- Remove Fuse & Replace Fuse***
- Reassemble in reverse order.
  • You can easily verify its the fuse by placing something conductive in the fuse socket in lue of the fuse, put batteries in and test continuity of fuse and connectors. Make sure black lead is connected into the middle socket and the red lead into the right socket.
Puntuación 0
I have used a Thsinde 18B+ Multimeter reliably for several years. However, it recently started to beep on any setting without giving a reading. I noticed that the display was showing a low battery even though I knew the battery was good. I thought the problem might be a high-resistance battery contact that had developed over the years, that was dropping most of the battery voltage, so sprayed all the battery contacts with contact cleaner. That fixed the problem.
Puntuación 0
have a BK 388B unit that is beeping on any setting. All contact good and Fuses are good.
Puntuación 0
1 comentario:
Check 500mA fuse, if it's good, check track, if track is good, there will be one diode or resistor which is open, finding value of components is very difficult,
Fuse visible looks good, short with jumper and try....
- de
Añadir tu respuesta
Francois Saaiman estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 55
Ultimos 30 días: 290
Todo El Tiempo: 84,927
