Saltar al contenido principal
The Asus Memo Pad 7 Me572C was announced in September of 2014. It is lightweight, slim, and contains many high-tech features. It comes in black, gold, and dark red.
Where can I find a guide for screen replacement?
Hi! My Asus Memo Pad 7 has a cracked screen and I would like to replace it. I've read that I may need to order a Asus Google Nexus 7 2nd Tab 2 2013 screen for the replacement, but I am unsure of how to take the screen off, and I've yet to find a guide on this, or any other, website. Could someone point me in the right direction for the screen replacement guide?
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
1 Respuesta
Solución Elegida
is this a memo pad 7 or a pad HD 7 ? Kinda need to know to help Also need to know if your replacing just glass or complete assembly
and dont order
Fue útil esta respuesta?
Puntuación 2
10 comentarios:
It's the Asus Memo Pad 7 ME572C (2014)
- de
you need to be specific about you glass . The Nexus is a higher end tablet and will likely have a different connector
- de
I'm pretty sure the complete assembly needs replaced. The screen stopped responding to touch in the area of the crack, but I don't have many clues to go on besides that, and that the crack was not due to fall damage (so no cables should have jostled themselves loose)
- de
Are you going to replace the lcd as well?
- de
this guide is enough to get you inside
Disassembling ASUS MeMO Pad 7 (ME572C) Rear Panel
from there all you need to do is replace the display assembly.
- de
Mostrar 5 comentarios más
Añadir tu respuesta
Noetic Syntax estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 1,127
