Saltar al contenido principal
Disassembling ASUS MeMO Pad 7 (ME572C) Rear Panel
Qué necesitas
  1. Disassembling ASUS MeMO Pad 7 (ME572C) Rear Panel, Rear Panel: paso 1, imagen 1 de 2 Disassembling ASUS MeMO Pad 7 (ME572C) Rear Panel, Rear Panel: paso 1, imagen 2 de 2
    • Make sure your device is turned off. Then with a plastic opening tool, carefully remove the back panel by carefully working your way around the perimeter.
    • The panel will be glued on and requires pressure to open.
  2. Disassembling ASUS MeMO Pad 7 (ME572C) Rear Panel: paso 2, imagen 1 de 3 Disassembling ASUS MeMO Pad 7 (ME572C) Rear Panel: paso 2, imagen 2 de 3 Disassembling ASUS MeMO Pad 7 (ME572C) Rear Panel: paso 2, imagen 3 de 3
    • After removing the rear panel, use a plastic openning tool to remove the frame of the tablet.
    • Start in the middle of the top side and insert a plastic opening tool between the screen and the frame.
    • Carefully run the plastic opening tool along all the edges of the tablet.
  3. Disassembling ASUS MeMO Pad 7 (ME572C) Rear Panel: paso 3, imagen 1 de 1
    • When you take the rear panel and the frame out, place the rear panel and the frame away from the device.
Conclusión
8 personas más completaron esta guía.
Efe Guldogan
Miembro Desde 08/26/15
860 Reputación
4 Guías creadas
Equipo
USF Tampa, Team 14-23, Meier Fall 2015 Miembro de USF Tampa, Team 14-23, Meier Fall 2015
USFT-MEIER-F15S14G23
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 40
Todo El Tiempo: 13,635
