perserving heel and soul using silicone
New boots showing wear after being worn 4 times. Would a coat of silicone protect against wear?
Es esta una buena pregunta?
You may be able to use silicone to rebuild your worn outsole, though the success of this repair might depend on the product you are intending to use and the type of material your outsole is made out of (leather, rubber, etc.).
A tried-and-true product specifically used for shoe repair is Shoe Goo. Here are two guides to help you complete the repair:
Hope this helps!
Guía
Dificultad:
Moderado
30 minutes
Guía
Dificultad:
Muy fácil
15 minutes
Fue útil esta respuesta?
If these are leather you can use several things:
These are made of hard plastic:
http://www.amazon.com/Traveler-Plates-Na...
These are nylon:
http://www.ebay.com/itm/10-pr-Guard-Heel...
These are metal:
http://www.ebay.com/itm/DIY-metal-BIKER-...
These are hob nails, worked well for the German army:
Here's something you might try. A bit costly I admit, but your shoes will wear down the pavement instead of the other way round ;)
(sorry, couldn't resist)
You dont want to walk on any glass floors with those shoes
我不知道!我不知道!我不知道!我不知道!我不知道!我不知道00!
At least you know you dont know
Ultimas 24 horas: 2
Ultimos 7 días: 15
Ultimos 30 días: 57
Todo El Tiempo: 3,918
1 comentario
I sprayed silicone on the boot material
- de michelle.jarvid
