Saltar al contenido principal
How To Fix a Hole in the Sole of a Shoe
Qué necesitas
  1. How To Fix a Hole in the Sole of a Shoe, How To Fix a Hole in the Sole of a Shoe: paso 1, imagen 1 de 1
    • To begin, clean the Adidas Gazelles with some water on a towel.
    • Be careful not to use too much water or you could further damage your shoes.
  2. How To Fix a Hole in the Sole of a Shoe: paso 2, imagen 1 de 2 How To Fix a Hole in the Sole of a Shoe: paso 2, imagen 2 de 2
    • Carefully use the utility knife to free the hole of any excess material.
    • Make sure and clear the Gazelles of any debris that that could be stuck under the loose squares of the sole.
  3. How To Fix a Hole in the Sole of a Shoe: paso 3, imagen 1 de 1
    • Use 100 grit sandpaper to roughen the inside surface of the hole.
    • This will help the shoe goo grip the surface of the shoe, and produce a more lasting fix.
  4. How To Fix a Hole in the Sole of a Shoe: paso 4, imagen 1 de 2 How To Fix a Hole in the Sole of a Shoe: paso 4, imagen 2 de 2
    • Apply shoe goo to the inside of the hole in the sole of your Adidas Gazelles.
    • Make sure to apply evenly to avoid making your Gazelles off balance.
    • If there is anywhere else on your Gazelle's sole that could use additional protection, apply shoe goo to those surfaces as well.
  5. How To Fix a Hole in the Sole of a Shoe: paso 5, imagen 1 de 1
    • Take your putty knife and smooth the shoe goo flush to the surface of the sole.
    • Try to spread the shoe goo in one direction to increase surface smoothness.
  6. How To Fix a Hole in the Sole of a Shoe: paso 6, imagen 1 de 1
    • Now place your Gazelles in a safe and clean place to dry for 24 hours.
  7. How To Fix a Hole in the Sole of a Shoe: paso 7, imagen 1 de 1
    • After 24 hours, use 150 grit sandpaper to rub down the surface of your filled hole to create a smooth surface.
Conclusión
Now with the hole repaired your Gazelles are ready for action. With the proper care you can extend their life for many years to come.
10 personas más completaron esta guía.
Hayden
Miembro Desde 04/09/15
497 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 28-3, Green Spring 2015 Miembro de Cal Poly, Team 28-3, Green Spring 2015
CPSU-GREEN-S15S28G3
4 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 26
Ultimos 30 días: 116
Todo El Tiempo: 20,540
