How can I replace my LCD Screen?
My screen recently broke, it refuses to turn on. I read through the tear down and was unable to determine what I should do in order to replace the screen.
Es esta una buena pregunta?
Hi Mitch,
Try taking a look at the LCD replacement guides for similar models. The HP EliteBook 8440p has a LCD replacement guide and so does the HP EliteBook 6030p. You can also find a replacement part on Amazon. The replacement LCD for your laptop can be found here. Be sure to double check your model numbers to be sure you've ordered the correct part. Good luck!
Guía
Dificultad:
Moderado
45 minutes
Guía
Dificultad:
Fácil
20 - 30 minutes
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 11
Todo El Tiempo: 2,794
