Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
El Asus X551CA es un ordenador portátil de 396.2 mm con características prácticas para el uso diario.
Keyboard malfunction,hardware or software problem?
Okay so i know this is not the keyboard itself because i have replaced it and didn't fix the problem. Scanned my whole computer and found no viruses, what the problem is, is that if i were to press key "3" that's above letter "E" it would show up as ".74231" if i press letter "E" the results i get are "hge9+" also the caps lock and spacebar act like this, not every key but about a handful of them do. I have already tried the "fn" "num lk" technique but it still does it.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 4
4 comentarios:
74231.7423174231.p7s 74231i have th74231i
I have the same problem! ugh. glad im not alone! all of the same problems although when i brought it to best buy to look at it they found nothing. they ..7423174231.74231.even kept it for a couple days and it didnt do it for them. but only for me. smh. i learned that if you slap the laptop with your hand, it will calm down for a few moments and stop...yup, the good ol fashion american way....lol.
- de
experiencing the same problem. Any updates? Please help me!!!!
- de
My guess is liquid damage / corrosion on keyboard connector, controller chip or circuit traces between kb connector and control chip.
- de
Tengo el mismo problema, además la tecla de la "barra espacio" escribe "nbz ". Lo curioso es que el problema desapareció en 2 ocasiones que no estuve conectado a internet (5 horas aproximadamente), pero luego volvió al conectarme a internet.
- de
Agregar un comentario
3 Respuestas
Your device is fine, its your key board. Junk the board and get a new one. I have two or more of these a month from friends an family. Ive worked on the boards to fix this isue. There is only one fix, a new key board.
Fue útil esta respuesta?
Puntuación 0
1 comentario:
I don't think you read what i had said, if its my keyboard then why did the other keyboard i ordered from EBay had the same problems? It was even tested and said to be fully functionable.
- de
Had a similar problem with Shift “p” in order to print “P” I get “P&$@#!” instead and I get 74231 if I try to type “p”. The backspace also gives me sometimes 74231 and the cursor jumps to the begining of the line.
I actually had replaced the battery short time ago with a higher and stronger battery because there is no battery similar to the original one. It looks like the new battery fried the laptop.
Puntuación 0
I have also the same problem. Now i connected wireless keyboard and it is working fine.
Puntuación 0
Añadir tu respuesta
redacted estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 9
Todo El Tiempo: 3,160
