Saltar al contenido principal
Reparar información en unidades de disco o discos duros. Los discos duros son dispositivos magnéticos de almacenamiento de datos. Se utilizan en la mayoría de las computadoras de escritorio, portátiles y servidores debido a su bajo costo y alta densidad de datos.
Preguntas 20 Ver todo
Adapter cable to connect a SATA HD?
Wondering if there is an adapter cable that can be hooked into firewire or USB to power-up and read an external SATA drive (one removed from another failed PowerBook or MacBook for data recovery)
Perhaps a pin-out diagram to make one up would do.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
4 Respuestas
Respuesta Más Útil
what you're looking for is one of these universal USB 2.0 drive adapters - you can find other manufacturers too, not just this particular brand
FAR more versatile than an external firewire enclosure. a must-have tool for anyone who often takes apart computers and needs to transfer data between drives. - inexpensive and can interface to many different kinds and physical sizes of drives.
Fue útil esta respuesta?
Puntuación 1
2 comentarios:
These things are great. I used one when I had to clone my hard drive, and it was simple dimple. I have a couple of enclosures, but those work much better when you're making a permanent home for a drive.
- de
The adapters are indeed very helpful, but it's worth noting that if you're moving a lot of data around or wiping a drive, a firewire hard drive enclosure is a lot faster.
- de
You need a hard drive enclosure, you cant just connect it straight to the firewire port as there is complex circuitry involved. You can find one here
Puntuación 0
Thanks everyone, I think the question is answered.
Merry Christmas to all... I'll see if there is still time for Santa to dredge up an adapter cable for me.
D
Puntuación 0
Ok... Thanks for the info. However, are you sure this will work for a HD from a MacBook? The HD is a Seagate Momentus 5400.3 120GB. I bought a similar adapter, a Vantec, and the connectors did not fit the HD. Has anyone used the product on the link above for a Mac Laptop HD?
Puntuación 0
1 comentario:
The seagate is only a sata disk (ok, ncq - but the connector is the same). i can read, write and boot the connected devices. look out for a set with sata support.
- de
Añadir tu respuesta
damaclac estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 3,357
