Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
El Sony Xperia J es, sencillamente, un smartphone que funciona con software Android.
Problem with network signal
I have a problem with my network signal.
I opened phone and found out that the connector from the second (lower) board has broke.
By the connector i mean the one that has a screw hole in it, its by the vibration mechanism.
picture of the board
So i would like to know if that's why i don't get network signal, or should i investigate more?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
3 Respuestas
Do you mean this connector?
Imagen
If this connector is broken you may have a problem with network signal strength. You need to solder it or replace this subboard. A good idea is the replecement of the rf cable (a black cable connected to this subboard).
Fue útil esta respuesta?
Puntuación 0
The problem that you state.have different problem with mine situation
Puntuación 0
It seems that the RF connector is damaged...kindly look at the condition maybe that is the reason and you need to replace.
Puntuación 0
Añadir tu respuesta
filerzr estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 17
Todo El Tiempo: 3,156
