Saltar al contenido principal
Screen clicks randomly by itself
My iPhone 5 is acting crazy. It is clicking by itself randomly and the screen is randomly unresponsive so suddenly it responds. I changed the touch screen twice, reinstalled IOS from scratch. Nothing of this helps. It is still acting crazy.
Here are some pictures of the digitizer connector. Were you wondering if there were any uncovered contacts?
Some pictures of the connector here:
Here is the connector after I cleaned it with isopropanol and a soft toothbrush:
After cleaning. Did not help on the issue.
I took off the tape. This was the best picture I could get
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
11 comentarios
Show us a picture of your digitizer connector
- de
Need a picture of the digitizer connector on the iPhone logic board.
- de
Added some pictures of the cable and connector. Hope they are good enough to check.
- de
Gently scrub the connectors on the board (in the picture) using a soft brush and a little bit of 90%+ isopropyl alcohol. Any change? (Keep the alcohol away from the screen, it will damage it)
A few things I noticed on your phone: connectors are dirty. There is something on them (at least one of them) that would require cleaning as per the above.
And one of the screw brackets is gone. And may be the black *foil* covering the area between the cable connectors is disturbed, as if it was previously removed then put back. What is the history of this phone? Did you get it new or used? Did it suffer from any incident such as drops, liquid damage, etc.? How/when/why did it start acting crazy? Following any particular incident?
- de
Here is the history. Someone gave me this iphone probably because of the issue. He had sent it to repair but they have done a bad job, e.g. you see the missing screw thread. I was told it was not dropped or had liquid damage but I could be wrong on both events. The liquid indicator to the bottom right of the battery is white.
- de
Mostrar 6 comentarios más
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Asle,
We don't see any visible damage on your digitizer connector or surrounding area in the picture. But still, I would expect this to be related to the connector. I would think it would be worth it to try a connector replacement. I would offer that as a solution for you in this case---If you want to do a mail in repair I would quote this as a "solution' i.e solve the ghosting problem with a new connector or no fee.
Find your way to my mail in repair website via my profile.
jessa
Fue útil esta respuesta?
Puntuación 1
should be capacitor leakage. its very rare fault. if you can change thme which comes with ground
Puntuación 0
2 comentarios:
Are you guessing or do you see it in the pictures?
- de
capacitor leakage cannot see in physically. i guess it. check the logic board with qualified technician.
- de
Añadir tu respuesta
asle estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 12,402
