What if my Wi-Fi network goes offline?
If my Wi-Fi network goes offline, will the thermostat still operate as programmed?
Es esta una buena pregunta?
Yes, if the Nest goes offline, it will continue to function as usual. You will not be able to adjust settings with your phone or computer, but adjustments can be made manually on the Nest itself.
Fue útil esta respuesta?
i think so---we've had a NEST for awhile and the network has gone down from time to time. I've never noticed a problem with the NEST---well, except for the time it fried the furnace.
Um, could you, er, please, explain your comment? It's funny, but I'd like to know the backstory.
I would like to know as well cause I had a problem with my a/c and wonder if the Nest is to blame.
Fried the furnace ?
Yes, it will work.
When you say the NEST occasionally cannot be reached by WiFi, that's another matter. For a while I thought it was the WiFi router, that NEST is particular re the brand/model. Accidentally one day I noticed that the iPhone app always connected if I had previously closed the app. Hmm... Sure enough, when I remember to close the app after I have made the change to the thermostat, I connect every time! Leave the app running in the background and it refuses to connect. That annoying blue circling thingy keeps circling then you get a troubleshooting "help" that's useless.
One more thought. Our offices and my home are two floor buildings. Heated air goes up the stairs to the 2nd floor; that's life. The HVACs do not have zone dampers (the office did (Lennox) but we chucked them as there was so much bypass of hi presssure air. Instead we place wood plates over the floor registers on the floor that's not being conditioned (summer = 2nd floor is cooling, winter = 1st floor is heating). In the offices we have had two NEST thermostats in parallel. We use the one we need and turn off the other. In the home we did not do this. So today we are buying the 2nd home thermostat so that when we retire for the night (it's 11F outside now - BRRRR) since heat rises, why control the 1st floor when we are on the 2nd? We have WaterFurnace Ground Source heat pumps plus an oil fired hot water heater and hot water packs in the air handlers heat the buildings in winter as our heat pumps cannot extract enough energy.
with HA sch 8 housing conjoined With the Owner(s) Individual or Authorized Property Management Company that All Electronics are integrated into their Computer synchrony system to have control of their tenants to make life pleasant or a tenant from hell that thinks smarter than ever yo one else.
Or a scammers heaven to scheme for self gain.
How can it stop?
does Nest have a shelf or expiration date expantcy? why should I be responsible for replacement or be accountable to become a Red Flagged Business Corporates Nuisance?
Yes it will. Have had this happen to me. As long as there is power to the thermostat it will work but you will not be able to communicate with it.
If your Wi-Fi goes out, your nest will act like an idiot and not be very smart. It will stop heating and cooling your house even if you have a program scheduled. This is not a smart device.
Ultimas 24 horas: 3
Ultimos 7 días: 14
Ultimos 30 días: 66
Todo El Tiempo: 48,097
1 comentario
We are snowbirds & turn off our cable & internet @ our condo when we head north. We have the same service (Spectrum) up north. Will we be able to control the Nest up there?
- de Steve Myers
