Saltar al contenido principal
El C720 es un Chromebook de bajo costo basado en Acer ChromeOS. Lanzado 2014 sucesor del C710.
Preguntas 26 Ver todo
Can I upgrade the RAM of my Acer C720 Chromebook?
I am not receiving the performance that I had expected. Videos and games look like they are sputtering during play. I cannot open more than a few tabs before the Chromebook comes to a crawl.
Es esta una buena pregunta?
Puntuación 9
Agregar un comentario
7 Respuestas
Solución Elegida
mibolsa,
SWAP is not quite the same thing as RAM although they do essentially the same thing from a higher level looking down, but swap is far slower and implemented with a storage device such as a hard drive or a solid state drive instead of memory. So this will help in some situations where the 2gb in my Chromebook is just not enough but not as quick as a physical ram module which is what was asked in this question.
Not trying to respond rudely just wanted to make the distinction for any future readers. Your answer was helpful just not 100% the correct answer for this problem, but is a solution. However swap on an ssd is ill advised due to r/w count. So I would not do this.
Fue útil esta respuesta?
Puntuación 2
4 comentarios:
what is ssd or r/w count?
- de
what is a ssd & r/w count!
- de
An SSD is a solid state drive. R/W count is read/write count. As you write data to an SSD, flipping 1s to 0s and vice versa, you physically wear out the device. This effect is present in all solid state memory, as far as I know, but it worse on the eMMC drives that are typically used in Chromebooks relative to the traditional NAND drives.
tl;dr:
The more stuff you write to a Chromebook's hard drive the sooner it will die.
- de
The R/W count problem is a bit exaggerated. It will shorten the overall lifespan of the SSD, but it's not "ill-advised", considering how its unlikely to be anyone's main, everyday workhorse... I would consider this advice the result of too much detailed tech knowledge and not practical usage advice.
- de
Respuesta Más Útil
Hello Christopher, and welcome to iFixit. I see this is your first question. Sadly the Acer C720 does not allow for you to upgrade your memory exclusively; however, you are able to upgrade the memory to a maximum of 4 GB by replacing the motherboard itself to a model with 4 GB. Follow the guide on the Acer C720 device page for replacing the motherboard.
Puntuación 7
1 comentario:
is that necessary.?
- de
Hope this is not a too late answer.
To activate SWAP, you will need to open terminal (Ctrl + Alt + t). In terminal, type the following command:
swap enable 2000
This will create a 2GB SWAP partition on your Chromebook’s SSD, adjusting the number will change the SWAP size. The Chrome team recommends 2GB. A restart is required to activate your newly created SWAP partition. It is regarding as an experimental feature, and is not recommended for daily use. To disable the SWAP partition type the following command in terminal and restart:
swap disable
Hopefully this feature will prevent your Chrome tabs from crashing and you should be able to use more tabs. A handy feature until we get Chromebooks with more RAM.
Puntuación 4
1 comentario:
SWAP disable
- de
The memory usage is proportional to the number of pixels on the screen because the laptop stores bitmaps for many of the background windows. Therefore, make sure your laptop is set to 1366x768 or 1024x576 to minimize RAM usage (hit crtl-shift-+ and crtl-shift-minus to change the resolution of the display). Also, remove as many browser extensions as possible to maximize cpu performance.
Puntuación 4
Upgrading ACER-c720 Chromebook on-board system memory!
If your machine has only 2GB of system memory on-board, you can have an engineer flow the empty spaces with more memory allowing the system to reach the maximum of 4GB, However, this can be achieved by you if you have electronic skills.
I purchased a dead mother board from eBay, found that the video card had failed, so I replaced the SMD component with a 2nd hand part from another Motherboard using a hot air gun, and it worked fine, the same applies to adding memory . Although, these components are not necessarily replaceable. This is just a myth, in order for the customer to buy a new Chromebook.
The whole re-work procedure should take no-longer than 5-minutes to complete.
See (you-tube) videos on replacing 2nd-hand SMD components!
ONE NOTE to point out is, if you do change or upgrade the Motherboard, you may have to re-install the Operating System from an SD-card back to the SSD. You could also upgrade the SSD to 32, 64 or 128GB giving you ample space to swap the memory to the SSD, leaving the on-board memory for the running CPU tasks...
Puntuación 1
How do I put a Windows Microsoft ram into a acer Chromebook c720 and also how would I replace the motherboard with the Windows Microsoft ram into Acer Chromebook c720
Puntuación 0
1 comentario:
You don't. The RAM used for normal laptops doesn't work with chromebooks. The RAM chip for a chromebook is a surface mounted component soldered to the motherboard.
- de
@John van Dongen's answer: Although removing SMDs can be relatively simple, resoldering connections for a replacement SMD is very difficult. All of the connections do need to be resoldered. This is not a "trick", hardly any customers want to take the machine totally apart and do their own soldering, which is risky in the best circumstances. “Although, these components are not necessarily replaceable. This is just a myth, in order for the customer to buy a new Chromebook.” HUH?!?! It’s true the components are not necessarily replaceable. One of the obvious reasons not to desolder. How is that a myth? Does “myth” apply to something else?
“The whole re-work procedure should take no-longer than 5-minutes to complete” HECK NO! It should take less than five minutes to desolder then decide to throw it out, because you’ve broke it beyond reasonable repair. lol
Also, in these old “netbooks”, everything is on the motherboard, it’s tightly integrated. There’s no way to upgrade the motherboard, as no other motherboard will fit. It’s sort of ridiculous to suggest it. I’ve never heard it to be a reasonable suggestion for any laptop. You can salvage and sell the screen for other people’s blown screens, but the C720 has a lousy, outdated screen, it’s not in much demand.
Puntuación 0
3 comentarios:
May I refer to the task of replacing SMD components. First the component can only be removed using a hot-air gun, After 20-seconds or so the chip should become lose enough ready to be removed from the board. I then use liquid flux to clean the circuit up with an Iron and solder wick, taking care not to apply too much heat, this however does take time, so patience is high on the list, being that too much heat can destroy the track you're working on, or worse case lift the track off completely causing even more repair. I then apply using "IPA" to thoroughly clean the board re-moving all the flux-residue preparing it for the next stage, The next job is to re-ball the chip with 0.01 solder-balls using a SMD solder mask, heat it to around 600c for 5-minutes. When the balling has adhered to the chip then its ready for replacing back to the MB once the mask has been removed. The success rate for this technique is tricky, I would suggest trying it with known duds first to get the feel & experience.
- de
Touché, you actually responded. Well, there might have been some jealousy and frustration in my comment. You have given helpful hints here, although as you suggest, I'm not sure the average ifixit reader is ready for this kind of work.
- de
@tibby ONLY a hot air gun? I use a soldering iron and hane no problem removing SMD components. I've been doing this type of work for 30 years now...
- de
Añadir tu respuesta
Christopher estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 57
Todo El Tiempo: 36,659
