Why wont it charge or turn on?
I have a m horse n9000 very similar to the note 3. Had the phone on once now it won't charge or turn on. Will someone please help
Es esta una buena pregunta?
La tercera generación de la serie phablet de Samsung Galaxy Note se lanzó el 25 de septiembre de 2013. Identificable por el número de modelo N9005.
This will work even if the phone will not power up try this and I do this every six months just to reset this setting. Solution:
Turn the phone off.
Remove the battery.
Wait 10 seconds.
Plug in the charger.
Insert the battery.
Turn on the phone.
Comentarios:
dude ur it kinda did work for my s4 but as soon as it turned on the battery symbol poped up and the phone shut off
- de Hassan Mahmood
My samsung Was switched off until 2 days i didnt tell anyone at home Now i saw this Method And this really works Thank You so much harley middleton
- de shaheen
Thanks this revived my Note 3
- de Mark Elmes
This worked for my Note 3 in the year of 2020. When the phone was revived, the battery had a 90% charge so the fault wasn't because the battery had no charge.
- de Abdoult Bank
I am assuming that when you charge your phone, absolutely nothing happens. The charge LED doesn't light up, buttons are not responsive, soft or hard resets do not work at all. Basically your phone seems like it is bricked (dead). You need to check for a couple of things:
1. Take an old toothbrush and brush the charger contacts on your phone as well as the charger. You may have accumulated gunk there that is preventing the phone from charging properly. This is an unlikely fix.
2. Your charger port may be faulty and would need to be replaced. That is one of the cheaper fixes (Amazon and other sites sell them for relatively cheap), if this is your actual problem. There's a faint chance this will resolve the problem but try the proposed solutions in order.
3 If after changing the charger port the problem still persists, your battery may need to be replaced. This option will likely fail, especially if the charger port replace did not work. Hold off and try #4 (or have a professional do this for you).
4. The problem then lies in your motherboard, particularly the power supply chip. I believe that there are 2 of them on the Note 3. I ordered both the larger and small one (you will need magnifying glasses to do this by the way). You will need a heat gun (or hot air station), the supply chip(s) (ordered from sites like enrik.com or aliexpress.com or ebay.com or other similar sites). You will also need anti-static or anti-magnetic tweezers, solder paste (not flux) and material to clean any residue. Many sites will tell you how to do it but never give you the details you with respect to actual tools and materials. A word of caution about the heat gun if you are doing this on your own. Make sure it is one with a very small opening as you are applying heat to a TINY, TINY area on the motherboard. You may need to by a nozzle attachment. I believe there are many sites that will show how to take the phone apart, just get the items mentioned or see a professional and see what the end result is. Can't be worse than what you have now, which I assume is a dead phone. Please let me know how it goes.
Rep: 1
We have had trouble too so I went looking online. Found this: http://www.askmefast.com/Why_wont_my_sam...
Seems to be a common problem. I went to Samsung site and chatted with an agent who didn't have a clue. Don't bother. Several people at that link above found that the geeky dude fix there worked for them. Worth a shot.
Rep: 1
my samsung galaxy is not able to charge
Rep: 1
my note is fully charged however every time i turn it on. all it does is display the samsung in the middle of the screen and stays there. eventually the phone gets so hot that the only thing to do is turn it back off..
help
Rep: 1
me too have similar problem to this issue. can anyone help
Comentarios:
Take the battery out of phone using a qtip with rubbing alcohol clean the contacts on the battery and the contacts on the phone itself. Also, give the USB port a good cleaning with a toothpick and napkin-paper towel and small piece to clean the contacts. If that does not do the trick then get a new wall wort and charging cable and a anker battery from amazon has good deals and not a wallet killer. Also try this This will work even if the phone will not power up try this and I do this every six months just to reset this setting. Solution:
Turn the phone off.
Remove the battery.
Wait 10 seconds.
Insert the battery.
Turn on the phone.
- de Harley Middleton
Rep: 1
That happened to me I need help as well
Comentarios:
Turn off the device.
Press and hold these three buttons at the same time: Volume Up, Home, Power Button.
When “Note 3” appears on the screen, let go of the continue to hold down: Volume Up and Home Button.
When the Android System Recovery screen appears, release the Volume Up and Home keys.
Press the Volume Down Button to select: Wipe Cache Partition.
Press the Power Button to select and wipe the cache.
With Reboot System Now highlighted, press the Power Button to restart the device.
Ultimas 24 horas: 4
Ultimos 7 días: 33
Ultimos 30 días: 116
Todo El Tiempo: 29,721
It's very annoying
- de Daneil
Take the battery out of phone using a qtip with rubbing alcohol clean the contacts on the battery and the contacts on the phone itself. Also give the usb port a good cleaning with a toothpick and napkin-paper towel and small piece to clean the contacts. If that does not do the trick then get a new wall wort and charging cable and a anker battery from amazon has good deals and not a wallet killer.
thank you my phone turned on.
- de Hailey Greene
