Saltar al contenido principal
Quinta generacion de iPhone. La reparación de este dispositivo es fácil y requiere destornilladores, herramientas de hacer palanca, y paciencia. GSM/CDMA /16, 32, o 64 GB / Negro o Blanco.
Preguntas 2193 Ver todo
Will not recharge after battery replacement
Phone was not recognized on mac nor was it recharging off the wall using multiple apple cords so I replaced the battery. It was able to recognize on mac noticed it had shown the little lighting bolt next to bat. % in top right corner but it was not recharging. I did not thing to do a "hard" reset but the phone is now dead. I did a little research and found that a pin in the dock connector could be bad but I have not yet dismantled my phone dock connectors look to be fairly inexpensive any other suggestions?
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Solución Elegida
Kyle, you are going the right way. Absolutely correct way of doing it. First the battery, then the dock connector, then it gets complicated; logic board issues. Here is the guide for the job. Not very complicated nor expensive. Let us know how it worked out. Of course, make sure that you check your battery connections thoroughly as well. Hope this helps, good luck.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Kyle estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 77
