Saltar al contenido principal
Una videoconsola producida por Sony Computer Entertainment, también conocida como PS4. Anunciada el 20 de febrero de 2013 y lanzada el 15 de noviembre de 2013.
Preguntas 1696 Ver todo
Power Supply is damaged
I have had a client that a roach went into the power supply of the PS4 and damage the components. I have been trying for some time now to see where I can obtain power supply separately. Any suggestions? Please contact me at c.fl
Es esta una buena pregunta?
Puntuación 9
14 comentarios
Has your client contacted Sony to see if a warranty replacement is valid?
- de
No she has not, also the warranty seal already been removed. The ps4 was infested with a small colony of roaches by the time I got to it.
- de
I think she has bigger issues than the PS4 power supply.
Anywho, researching your question more. Are you referring to the external power brick or the power inlet on the back of the console?
- de
I was speaking of the power inlet in the back of the ps4. And no there is no bigger issue I had obtain another ps4 from a friend and switch the PSU and the broken was able to start up.
Dakota I will go ahead and try what you mentioned. I'll post back if I find anything
- de
Actually I was referring to the roaches being the bigger issue.
- de
Mostrar 9 comentarios más
Agregar un comentario
4 Respuestas
Solución Elegida
Hi Charles, I was in the same boat in february, Just do a google search for the model of the power supply and I was able to source on on ebay for a little more than $100.
My PS4's PSU model was ADP-240AR.
YMMV,
Dakota
Fue útil esta respuesta?
Puntuación 1
So you’ve got a dead power supply and want to know why. The problem could be something simple, like a blown fuse or loose wire. If so, you might be able to fix the supply for less than $1. This article will outline how to replace a bad power supply fuse, saving you the cost of a whole new supply.
WARNING!
Working on a power supply should not be taken lightly or attempted by someone with little electrical experience. Even when the supply is unplugged, its components can remain charged and SHOCK YOU. If you are in doubt about your abilities, let an experienced repair technician do the work or simply replace the entire power supply.
If you do decide to open a power supply, remember to UNPLUG IT FIRST. Also, DO NOT WEAR A SHORTING BRACELET when working inside a power supply. You do not want to be in the current path of a discharging capacitor. Remember that power supplies are not the high-dollar items they once were and an hour of a tech’s labor is sometimes more than the cost of a new supply. If you do feel confident to work on a power supply, you do so AT YOUR OWN RISK.
Puntuación 1
You'll need to replace the PSU, or deep clean it. You can find YouTube videos to clean, but I'd replace it. Use the guide below to replace the power supply. You can get one from eBay.
Hope this helps!
Reemplazo de la fuente de alimentación PlayStation 4
Puntuación 1
My ps4 turn on but shut right back off and the fan not turning what can that be please help
Update (12/20/2020)
If I get a new power supply for my ps4 will it work again and the fan will run right
Puntuación 0
1 comentario:
I took my ps4 apart and I took out the power supply there is no power cord or anything else hooked up to it but I keep getting shocked. Does the power supply keep charged even though it's been disconnected from all power sources for 3 days now?
- de
Añadir tu respuesta
Charles estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 12
Ultimos 30 días: 33
Todo El Tiempo: 39,002
