Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
El HTC Desire HD es un teléfono inteligente Android de HTC Corporation.
Screen replacement help me
I have an htc desire hd phone with broken screen but the phone works smoothly and finely.
Should i have to replace the whole lcd screen or just the screen digitizer.
And if i have to replace only the screen digitizer , is it normal to replace the screen digitizer ande is it easy???
>>help<<
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
2 Respuestas
Solución Elegida
Amit Pathak , yes it is possible, but it is anything but easy. Check this video and this one for more information. Some more instructions on here as well. You will need a heat source to remove the digitizer from the screen. Check on this question as well. Hope this helps, good luck.
Fue útil esta respuesta?
Puntuación 3
Thank you for that informations.
Puntuación 0
Añadir tu respuesta
Amit Pathak estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 11
Todo El Tiempo: 1,878
