Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Dust on back camera
HI, i'm a proud padfon 2 owner, but after few months of use, I notice some dust on my back camera...wow!!!It's terrible!
Can you post a guide on how to clean the back camera?How can I try to do it?thank you.
Es esta una buena pregunta?
Puntuación -1
Agregar un comentario
3 Respuestas
Solución Elegida
Hi! Just go to step 5 in this guide, without disconnecting the battery. Sustitución de la Pantalla del Asus Padfone 2
Fue útil esta respuesta?
Puntuación 0
2 comentarios:
Hi! The protective camera lens just lays on top of the camera, so lay it back. Will make a guide sunday evening anyways! :)
- de
Im looking into a sultion using Photo-album-sticky stuff. Replacing my screen as soon as i get it, will try it then, and make a guide! :)
- de
I have the same problem, a guide would be nice :-)
Puntuación 0
2 comentarios:
Jonatan:
Well, I can see the Camera, but it also states that "Note that the protective camera lens will get loose!"
Right, I am not a technical genius, but how do I fasten the Protective camera lens again?
- de
Hi Jonatan
Do you have any good ideas how to prevent dust in the future?
Is it possible to seal it somehow?
- de
To stop dust getting in, jam "something" in the headphone jack. I found that cutting an old headphone plug off ( the part you put in the jack ), and then inserting it in backwards ( ie rubber bit in 1st ) and then cutting the rest down to an appropriate size works well. There are apparently plugs you can buy, but I can't find any locally. I guess you could also use bluetack or chewing gum or something :P
Puntuación 0
Añadir tu respuesta
Defteros estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 13
Todo El Tiempo: 4,215
