Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Monitor LCD Dell de 19", de color gris carbón, lanzado en 2004.
Screen not activating start button flashing
Monitor would not 'tun on'.Start button on bottom right hand corner was flashing and screen was blank.
Unplugged all leads and power to PC to get this going.
Don't know why this occurred.
Any ideas?
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
4 Respuestas
Solución Elegida
Warren, the flashing LED can be an indication that your monitor is having power issues. Recheck your connections, if all of them are okay, disassemble your monitor and check the caps on the power board. Use these guides to work on your monitor. It does sound like you are having a few failed capacitors. Hope this helps, good luck.
Fue útil esta respuesta?
Puntuación 0
Try using a different VGA cable.
Puntuación 0
1 comentario:
Thanks ,not the answer I was hoping for.but sounds correct.We managed to get it going all night then this morn same.but can't clear it this time.had a long hot summer so maybe board dried out etc.Thanks again
- de
i think symptom due to monitor.
Puntuación 0
I have a windows 11 monitor but the light by the intel core i7 is blinking and my screen is just black and idk what to do.
Puntuación 0
Añadir tu respuesta
Warren estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 31
Todo El Tiempo: 23,817
