Saltar al contenido principal
Unibody de aluminio de 13", procesador Core 2 Duo de 2.0 o 2.4 GHz.
Preguntas 20 Ver todo
Pregunta Cerrada
black plastic between de screen and the keyboard?
I want to change that black plastic peace in the outside of my mac between the LCD and the keyboard, Where can i find it???
Es esta una buena pregunta?
Puntuación 0
1 comentario
Thanks!! I was talking about the hinge clutch cover! Is that piece for an macbook late 2008?
- de
Agregar un comentario
2 Respuestas
Solución Elegida
It's not sold as a separate piece. It comes with a top case replacement. I haven't found what material it's made of, but if you did you could use the old one as a template. It's got to be some kind of heat resistant plastic.
Fue útil esta respuesta?
Puntuación 1
1 comentario:
See step #26 of this guide for removing the clutch cover: MacBook Unibody Model A1278 LVDS Display Cable Replacement
- de
Hi,
Are you referring to the front lcd glass/ bezel cover: http://www.ebay.com.sg/itm/New-Apple-MAC...
This one listed on ebay cost around $28USD (brand new). Replacing it aint easy as it is held on by glue which you'll need a heat gun to soften the glue. Plus a lot of strength! >.<
If it is the hinge clutch cover: http://www.ebay.com.sg/itm/Macbook-Unibo...
This one is listed on ebay for about $16USD.
Replacing this is very easy.
Puntuación 1
2 comentarios:
- de
Hi i found this on ebay: http://item.mobileweb.ebay.com.sg/viewit...
Im not sure whats your exact model but this one above is for model A1260. Do verify before buying. Hope it helps! :)
- de
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 1,049
