Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Guías para reparación de cocinas y hornos eléctricos y a gas
How do you remove door from Jenn-Air JMW9527BAB Oven?
My Oven Door - Jenn Air model# JMW9527BAB, does not have the standard removal method. No sliding bar or the ability to lift & remove.
The dust inside the glass is terrible, so I want to remove & clean.
Any ideas?
Es esta una buena pregunta?
Puntuación 2
2 comentarios
I can't get my oven door back in place...it's a Jenn air and the guy who brought it to me left the door beside it...I tried to look for a hole to put the pin in as Old Turkey mentioned in his comment, but it doesn't go through. When I try to fit it in, the hinges pop back into the closed position
- de
I managed to disassemble the oven door, but did not notice the fact that there were 2 different thickness' of glass panels until I began to clean the glass. I have re-assembled the door but I am unsure about the proper order of assembly. Also the thicker panel has an etched label (PVG) on one side. My question is...What is the proper order of re-assembly and which side of the thick (tempered ?) glass faces the interior ?
- de
Agregar un comentario
2 Respuestas
Solución Elegida
stuart, here is what the service manual suggest :
Open the oven door as wide as possible.
Place an 1/8" pin in the hole on the right and left door hinges, see Figure 2-1,
Remove the screws from each side with a Phillips screwdriver.
Remove the lock plate from each side, Figure 2-1
Raise the oven door up to a broil stop position. In this position, it will be against the 1/8" pin.
Grasp the door toward the top on both sides. Lift the door up and out to remove.
"SERVICING OVEN DOOR
1. Lay the oven door on a protected surface with the inner door panel facing down.
2. Remove three screws from lower trim.Remove trim piece.
3. Slide outer-door glass down to disengage from top trim. Remove.
4. Remove three screws from top oven door trim. Remove the two 3/8" nuts from the door handle bracket.
5. Lift up and off. This will disengage the side trim as well.
6. Remove the oven window pack by removing the 3/8" nuts from the insulation retainer."
Hope this helps, good luck.
Fue útil esta respuesta?
Puntuación 4
9 comentarios:
Thanks OldTurkey, I won't have time for a while, but I will try this.
- de
Sounds good, let us know if it worked for you.
- de
I will never buy a Jenn Aire again. It has been the worst oven ever. First the temp probe stops working and now the self clean oven won't work.
- de
tried your directions to remove my over door and worked like a charm, thanks for the tip!
- de
Thanks oldturkey03 worked perfect on my wives Jenn-Air double oven wall unit
#JJW8630. I cut to small pieces out of a wire coat hanger for the pins, fit
was just right.
- de
Mostrar 4 comentarios más
How do i adjust the door to close fully/ completely. My jenn-air oven model is JMW9527CAB
thanks James
Puntuación 0
Añadir tu respuesta
stuart estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 14
Ultimos 30 días: 80
Todo El Tiempo: 19,616
