Saltar al contenido principal
Samsung Refrigerator Icemaker Assembly Replacement (Refrigerator Icemaker)
Qué necesitas
  1. Samsung Refrigerator Icemaker Assembly Replacement (Refrigerator Icemaker), Unplug your refrigerator: paso 1, imagen 1 de 1
    • Unplug your refrigerator before you begin your repair.
  2. Samsung Refrigerator Icemaker Assembly Replacement (Refrigerator Icemaker), Open the refrigerator doors: paso 2, imagen 1 de 2 Samsung Refrigerator Icemaker Assembly Replacement (Refrigerator Icemaker), Open the refrigerator doors: paso 2, imagen 2 de 2
    • Open both French doors for the refrigerator compartment.
  3. Samsung Refrigerator Icemaker Assembly Replacement (Refrigerator Icemaker), Remove the ice bucket: paso 3, imagen 1 de 1
    • The ice bucket should be located in the upper left side of your refrigerator. It may have "Ice Master" or "Ice Max" on the outside.
  4. Samsung Refrigerator Icemaker Assembly Replacement (Refrigerator Icemaker), Remove the ice bucket: paso 4, imagen 1 de 3 Samsung Refrigerator Icemaker Assembly Replacement (Refrigerator Icemaker), Remove the ice bucket: paso 4, imagen 2 de 3 Samsung Refrigerator Icemaker Assembly Replacement (Refrigerator Icemaker), Remove the ice bucket: paso 4, imagen 3 de 3
  5. Samsung Refrigerator Icemaker Assembly Replacement (Refrigerator Icemaker), Check the ice bucket condition: paso 5, imagen 1 de 1
    • Check for cracks or fractures in the ice bucket and auger assembly. Replace the bucket as needed.
    • Check the gasket around the edge of the bucket. If the gasket's ripped, cracked, rolled or has become too rigid, the bucket won't seal properly and cause condensation to seep in and freeze.
  6. Samsung Refrigerator Icemaker Assembly Replacement (Refrigerator Icemaker), Unfasten the cable cover panel: paso 6, imagen 1 de 2 Samsung Refrigerator Icemaker Assembly Replacement (Refrigerator Icemaker), Unfasten the cable cover panel: paso 6, imagen 2 de 2
    • Remove the wire harness screw securing the cable cover panel.
  7. Samsung Refrigerator Icemaker Assembly Replacement (Refrigerator Icemaker), Remove the cable cover panel: paso 7, imagen 1 de 3 Samsung Refrigerator Icemaker Assembly Replacement (Refrigerator Icemaker), Remove the cable cover panel: paso 7, imagen 2 de 3 Samsung Refrigerator Icemaker Assembly Replacement (Refrigerator Icemaker), Remove the cable cover panel: paso 7, imagen 3 de 3
    • Use your fingers to slide the cable cover panel towards the front of the refrigerator to unlatch it.
    • Remove the cable cover panel.
    • During reassembly, make sure this panel clips fully in place, or the ice tray won't slide in properly.
  8. Samsung Refrigerator Icemaker Assembly Replacement (Refrigerator Icemaker), Disconnect the icemaker harness: paso 8, imagen 1 de 2 Samsung Refrigerator Icemaker Assembly Replacement (Refrigerator Icemaker), Disconnect the icemaker harness: paso 8, imagen 2 de 2
    • The exact configuration of the connectors may vary on your refrigerator.
    • Disconnect the left-most yellow connector:
    • Squeeze the locking tab with your fingers.
    • Rock the connector gently side to side to disconnect it.
    • Use your fingers or a screwdriver to guide the wire harness out of the wall clips.
  9. Samsung Refrigerator Icemaker Assembly Replacement (Refrigerator Icemaker), Unfasten the air tunnel: paso 9, imagen 1 de 1
    • Remove the ice maker screw securing the air tunnel flap.
  10. Samsung Refrigerator Icemaker Assembly Replacement (Refrigerator Icemaker), Remove the icemaker assembly: paso 10, imagen 1 de 3 Samsung Refrigerator Icemaker Assembly Replacement (Refrigerator Icemaker), Remove the icemaker assembly: paso 10, imagen 2 de 3 Samsung Refrigerator Icemaker Assembly Replacement (Refrigerator Icemaker), Remove the icemaker assembly: paso 10, imagen 3 de 3
    • A plastic clip holds the air tunnel flap in place.
    • Use a flathead screwdriver to pry and loosen the air tunnel flap from the plastic clip.
  11. Samsung Refrigerator Icemaker Assembly Replacement (Refrigerator Icemaker): paso 11, imagen 1 de 2 Samsung Refrigerator Icemaker Assembly Replacement (Refrigerator Icemaker): paso 11, imagen 2 de 2
    • Use your fingers to pull the air tunnel flap down enough to access the internals.
  12. Samsung Refrigerator Icemaker Assembly Replacement (Refrigerator Icemaker): paso 12, imagen 1 de 2 Samsung Refrigerator Icemaker Assembly Replacement (Refrigerator Icemaker): paso 12, imagen 2 de 2
    • Use a flathead screwdriver to gently pry the refrigerant loop down by 1–1.5 cm.
    • During reassembly, use your fingers to push the refrigerant loop back up.
  13. Samsung Refrigerator Icemaker Assembly Replacement (Refrigerator Icemaker): paso 13, imagen 1 de 3 Samsung Refrigerator Icemaker Assembly Replacement (Refrigerator Icemaker): paso 13, imagen 2 de 3 Samsung Refrigerator Icemaker Assembly Replacement (Refrigerator Icemaker): paso 13, imagen 3 de 3
    • A plastic clip holds the icemaker in place.
    • Use your fingers to press and release the plastic clip.
    • This clip is stiff and may require substantial force.
  14. Samsung Refrigerator Icemaker Assembly Replacement (Refrigerator Icemaker): paso 14, imagen 1 de 2 Samsung Refrigerator Icemaker Assembly Replacement (Refrigerator Icemaker): paso 14, imagen 2 de 2
    • Pull the front edge of the icemaker assembly down slightly to loosen it.
    • Be careful not to bend the refrigerant loop too much as you pull the front edge, or you'll damage the loop.
    • Carefully slide the icemaker assembly out of its housing.
  15. Samsung Refrigerator Icemaker Assembly Replacement (Refrigerator Icemaker), Removing the Ice Maker: paso 15, imagen 1 de 2 Samsung Refrigerator Icemaker Assembly Replacement (Refrigerator Icemaker), Removing the Ice Maker: paso 15, imagen 2 de 2
Conclusión
Be sure to dry any moisture that remains in the ice room before reassembly to prevent repair failure.
Repair didn’t go as planned? Ask our Answers Community for help.
nicO
Miembro Desde 04/14/15
15,927 Reputación
88 Guías creadas
Equipo
Global Fixers Miembro de Global Fixers
Community
33 Miembros
574 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 42
Ultimos 7 días: 166
Ultimos 30 días: 728
Todo El Tiempo: 3,618
