Saltar al contenido principal
Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker)
Qué necesitas
  1. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Unplug your refrigerator: paso 1, imagen 1 de 1
    • Unplug your refrigerator before you begin your repair.
  2. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Open the freezer drawer: paso 2, imagen 1 de 2 Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Open the freezer drawer: paso 2, imagen 2 de 2
    • Slide the freezer drawer fully open.
  3. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Remove the freezer bins: paso 3, imagen 1 de 3 Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Remove the freezer bins: paso 3, imagen 2 de 3 Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Remove the freezer bins: paso 3, imagen 3 de 3
    • Lift and remove all the freezer bins from the drawer.
    • You may need to open the refrigerator doors in order to remove the large bin.
  4. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Remove the freezer door: paso 4, imagen 1 de 3 Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Remove the freezer door: paso 4, imagen 2 de 3 Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Remove the freezer door: paso 4, imagen 3 de 3
    • A plastic tab locks each drawer rail in place.
    • Use a flathead screwdriver or your fingers to press in the plastic tab near the inner end of the drawer rail.
    • As you press the plastic tab, grasp the rail with your free hand and slide it towards you slightly to unlock the rail.
  5. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker): paso 5, imagen 1 de 2 Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker): paso 5, imagen 2 de 2
    • Repeat the rail unlock procedure on the other drawer rail.
    • Once both rails are unlocked, firmly pull both rails to slide them out of the refrigerator wall guides.
    • Remove the freezer drawer.
    • To install the freezer drawer:
    • Push the geared torsion bar until it rests at the very end of the rails.
    • Align the drawer rails to the refrigerator wall guides.
    • Close the freezer drawer until the rails lock back in place.
    • If you don't hear a click, visually check if the plastic tabs have locked in place. You may need to push the rails in a little further with your fingers to set the tabs.
  6. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Unfasten the icemaker assembly: paso 6, imagen 1 de 2 Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Unfasten the icemaker assembly: paso 6, imagen 2 de 2
    • Use a Phillips screwdriver to remove the screws securing the icemaker assembly to the freezer ceiling.
  7. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Disconnect the icemaker assembly: paso 7, imagen 1 de 2 Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker), Disconnect the icemaker assembly: paso 7, imagen 2 de 2
    • Grasp the front edge of the icemaker assembly and tilt it downwards.
    • Don't try to remove the icemaker yet, as it's still connected by a few wires.
  8. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker): paso 8, imagen 1 de 2 Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker): paso 8, imagen 2 de 2
    • Use your fingers to guide the wire harness out of the icemaker assembly.
  9. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker): paso 9, imagen 1 de 3 Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker): paso 9, imagen 2 de 3 Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker): paso 9, imagen 3 de 3
    • Squeeze the icemaker cable connector and pull to disconnect it.
  10. Samsung Refrigerator Icemaker Assembly Replacement (Freezer Icemaker): paso 10, imagen 1 de 1
    • Remove the icemaker assembly.
Conclusión
Repair didn’t go as planned? Ask our Answers community for help.
Arthur Shi
Miembro Desde 01/03/18
254,543 Reputación
529 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
136 Miembros
17,410 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 22
Ultimos 30 días: 56
Todo El Tiempo: 256
