Saltar al contenido principal
Samsung Galaxy S4 Bare Screen Replacement
Qué necesitas
  1. Samsung Galaxy S4 Bare Screen Replacement, Rear Case: paso 1, imagen 1 de 2 Samsung Galaxy S4 Bare Screen Replacement, Rear Case: paso 1, imagen 2 de 2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
  2. Samsung Galaxy S4 Bare Screen Replacement: paso 2, imagen 1 de 3 Samsung Galaxy S4 Bare Screen Replacement: paso 2, imagen 2 de 3 Samsung Galaxy S4 Bare Screen Replacement: paso 2, imagen 3 de 3
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  3. Samsung Galaxy S4 Bare Screen Replacement, MicroSD Card: paso 3, imagen 1 de 3 Samsung Galaxy S4 Bare Screen Replacement, MicroSD Card: paso 3, imagen 2 de 3 Samsung Galaxy S4 Bare Screen Replacement, MicroSD Card: paso 3, imagen 3 de 3
    • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the microSD card.
    • For reassembly, push the microSD card into the slot until it clicks in place.
  4. Samsung Galaxy S4 Bare Screen Replacement, Battery: paso 4, imagen 1 de 3 Samsung Galaxy S4 Bare Screen Replacement, Battery: paso 4, imagen 2 de 3 Samsung Galaxy S4 Bare Screen Replacement, Battery: paso 4, imagen 3 de 3
    • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
    • Remove the battery from your phone.
  5. Samsung Galaxy S4 Bare Screen Replacement, SIM Card: paso 5, imagen 1 de 3 Samsung Galaxy S4 Bare Screen Replacement, SIM Card: paso 5, imagen 2 de 3 Samsung Galaxy S4 Bare Screen Replacement, SIM Card: paso 5, imagen 3 de 3
    • Use a plastic opening tool, or your fingernail, to press the SIM card slightly deeper into its slot until you hear a click.
    • Remove the SIM card.
    • During reassembly, push the SIM card into the slot until it clicks in place.
  6. Samsung Galaxy S4 Bare Screen Replacement, Midframe: paso 6, imagen 1 de 1
    • Remove the nine 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
  7. Samsung Galaxy S4 Bare Screen Replacement: paso 7, imagen 1 de 2 Samsung Galaxy S4 Bare Screen Replacement: paso 7, imagen 2 de 2
    • The midframe is secured to the display assembly by several plastic clips behind the chrome bezel of the midframe. The next few steps will guide you through separating the clips to free the midframe.
    • Starting on the volume button side of the phone, insert your plastic opening tool between the chrome bezel around the display glass and the larger chrome border piece. Look for the seam between the two.
    • Slide the opening tool along the seam, separating the plastic clips as you go.
    • Be very gentle whilst prying, and pry only enough to separate the plastic clips—there are several thin points in the midframe bezel that may crack if you bend them too much.
  8. Samsung Galaxy S4 Bare Screen Replacement: paso 8, imagen 1 de 2 Samsung Galaxy S4 Bare Screen Replacement: paso 8, imagen 2 de 2
    • Continue prying around the corner of the phone.
    • Slide your opening tool along the seam between the midframe and display along the bottom of the device, releasing more of the plastic clips.
  9. Samsung Galaxy S4 Bare Screen Replacement: paso 9, imagen 1 de 2 Samsung Galaxy S4 Bare Screen Replacement: paso 9, imagen 2 de 2
    • Again, pry around the corner, to the power button side.
    • Slide the opening tool along the seam.
  10. Samsung Galaxy S4 Bare Screen Replacement: paso 10, imagen 1 de 2 Samsung Galaxy S4 Bare Screen Replacement: paso 10, imagen 2 de 2
    • Continue sliding the opening tool around the top of the phone, releasing the last of the clips and freeing the midframe from the display assembly.
    • At this point, you may want to run your plastic opening tool along the entire perimeter of the device again, to make sure you've released all of the plastic clips.
  11. Samsung Galaxy S4 Bare Screen Replacement: paso 11, imagen 1 de 3 Samsung Galaxy S4 Bare Screen Replacement: paso 11, imagen 2 de 3 Samsung Galaxy S4 Bare Screen Replacement: paso 11, imagen 3 de 3
    • Remove the midframe from the display assembly.
  12. Samsung Galaxy S4 Bare Screen Replacement, Motherboard Assembly: paso 12, imagen 1 de 3 Samsung Galaxy S4 Bare Screen Replacement, Motherboard Assembly: paso 12, imagen 2 de 3 Samsung Galaxy S4 Bare Screen Replacement, Motherboard Assembly: paso 12, imagen 3 de 3
    • Use the flat end of a spudger to disconnect the USB board connector.
    • Disconnect the front-facing camera cable connector.
    • Disconnect the earpiece speaker assembly cable connector.
  13. Samsung Galaxy S4 Bare Screen Replacement: paso 13, imagen 1 de 3 Samsung Galaxy S4 Bare Screen Replacement: paso 13, imagen 2 de 3 Samsung Galaxy S4 Bare Screen Replacement: paso 13, imagen 3 de 3
    • Disconnect the headphone jack assembly cable connector.
    • Disconnect the display/digitizer cable connector.
    • Disconnect the antenna cable connector.
  14. Samsung Galaxy S4 Bare Screen Replacement: paso 14, imagen 1 de 1
    • Remove the single 2.4 mm Phillips #00 screw from the motherboard assembly.
  15. Samsung Galaxy S4 Bare Screen Replacement: paso 15, imagen 1 de 2 Samsung Galaxy S4 Bare Screen Replacement: paso 15, imagen 2 de 2
    • Gently remove the motherboard.
    • Hold the motherboard by its edges to prevent ESD damage. Be careful not to snag it on any cables as you extract it from the display assembly.
  16. Samsung Galaxy S4 Bare Screen Replacement, Remove the speaker assembly: paso 16, imagen 1 de 2 Samsung Galaxy S4 Bare Screen Replacement, Remove the speaker assembly: paso 16, imagen 2 de 2
    • Use an opening tool to unclip the speaker assembly on the bottom of the phone.
    • Remove the speaker assembly.
  17. Samsung Galaxy S4 Bare Screen Replacement, Remove the antenna cable: paso 17, imagen 1 de 2 Samsung Galaxy S4 Bare Screen Replacement, Remove the antenna cable: paso 17, imagen 2 de 2
    • Use tweezers to lift and de-route the antenna cable from the edge of the case.
  18. Samsung Galaxy S4 Bare Screen Replacement: paso 18, imagen 1 de 2 Samsung Galaxy S4 Bare Screen Replacement: paso 18, imagen 2 de 2
    • Lift directly up on the antenna connection to remove it from the speaker daughter board.
    • Completely remove the antenna cable.
  19. Samsung Galaxy S4 Bare Screen Replacement, Remove the screen glass: paso 19, imagen 1 de 1
    • Prepare an iOpener (or use a hair dryer or heat gun) and heat the screen side of the phone to loosen the display adhesive.
    • Leave the iOpener on the phone for at least two minutes to fully heat the screen and soften the adhesive holding it to the case.
    • You may need to reheat the iOpener and repeat this procedure several times until the display adhesive gets loose enough.
  20. Samsung Galaxy S4 Bare Screen Replacement: paso 20, imagen 1 de 2 Samsung Galaxy S4 Bare Screen Replacement: paso 20, imagen 2 de 2
    Herramienta utilizada en este paso:
    Jimmy
    $7.95
    Comprar
    • Because the gap between the screen and phone frame is so thin, a Jimmy is needed to separate the two. Read the following warnings carefully before proceeding.
    • Even though the metal blade is mostly dull, be careful not to apply too much pressure, as this might cause the Jimmy to slip and cut you or damage the phone.
    • Wear eye protection. The glass may break, sending pieces flying.
  21. Samsung Galaxy S4 Bare Screen Replacement: paso 21, imagen 1 de 3 Samsung Galaxy S4 Bare Screen Replacement: paso 21, imagen 2 de 3 Samsung Galaxy S4 Bare Screen Replacement: paso 21, imagen 3 de 3
    • With the adhesive lose, insert the blade into the small gap between the frame and the screen, near the volume rocker.
    • Slowly slide the blade down the length of the phone towards the charge port to release the screen glass from the LCD.
    • The glass will most likely develop hairline fractures as you bend it during this step. Make sure you have proper eye protection.
  22. Samsung Galaxy S4 Bare Screen Replacement: paso 22, imagen 1 de 2 Samsung Galaxy S4 Bare Screen Replacement: paso 22, imagen 2 de 2
    • The next three steps involve removing extremely fragile components. Consider working on a surface that will be easy to clean up afterwards.
    • With the screen glass completely loosened around the edges, remove it from the phone.
    • The fragile LCD display underneath the glass has a tendency to shatter into small pieces. If in doubt, protect your hands with gloves.
    • Cover the LCD with tape to prevent the broken glass from spreading or falling out during removal.
  23. Samsung Galaxy S4 Bare Screen Replacement, Remove the LCD: paso 23, imagen 1 de 2 Samsung Galaxy S4 Bare Screen Replacement, Remove the LCD: paso 23, imagen 2 de 2
    • Carefully peel the cracked LCD away from the frame.
    • If necessary, push the Jimmy between the LCD and the frame to loosen it from the adhesive.
    • Remove the LCD.
  24. Samsung Galaxy S4 Bare Screen Replacement: paso 24, imagen 1 de 2 Samsung Galaxy S4 Bare Screen Replacement: paso 24, imagen 2 de 2
    • Grab the foil liner underneath the LCD and peel it away from the case.
    • You may need to reheat and reapply the iOpener to help loosen the adhesive.
  25. Samsung Galaxy S4 Bare Screen Replacement, Clean off old adhesive: paso 25, imagen 1 de 3 Samsung Galaxy S4 Bare Screen Replacement, Clean off old adhesive: paso 25, imagen 2 de 3 Samsung Galaxy S4 Bare Screen Replacement, Clean off old adhesive: paso 25, imagen 3 de 3
    • Use tweezers to remove all old adhesive from the phone case before installing the new display.
    • When you install the replacement display, feed the display cable through the hole on the rear of the case.
Conclusión
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Samsung Galaxy S4 Answers community for help.
27 personas más completaron esta guía.
Carsten Frauenheim
Miembro Desde 03/10/20
113,718 Reputación
338 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
135 Miembros
16,818 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 10
Ultimos 30 días: 35
Todo El Tiempo: 30,755
