Saltar al contenido principal
Lenovo Legion 5 15ACH6H Battery Replacement
Qué necesitas
  1. Lenovo Legion 5 15ACH6H Battery Replacement, Back cover removal: paso 1, imagen 1 de 2 Lenovo Legion 5 15ACH6H Battery Replacement, Back cover removal: paso 1, imagen 2 de 2
    • Use a Phillips screwdriver to remove the following ten screws securing the back cover to frame:
    • Six 12.5 mm PH1 screws
    • Four 4.7 mm PH1 screws
  2. Lenovo Legion 5 15ACH6H Battery Replacement, Release the front clips: paso 2, imagen 1 de 3 Lenovo Legion 5 15ACH6H Battery Replacement, Release the front clips: paso 2, imagen 2 de 3 Lenovo Legion 5 15ACH6H Battery Replacement, Release the front clips: paso 2, imagen 3 de 3
    • Insert the rounded edge of an opening pick between the back cover and the frame in the lower right corner.
  3. Lenovo Legion 5 15ACH6H Battery Replacement: paso 3, imagen 1 de 3 Lenovo Legion 5 15ACH6H Battery Replacement: paso 3, imagen 2 de 3 Lenovo Legion 5 15ACH6H Battery Replacement: paso 3, imagen 3 de 3
    • Angle the pick to about 30˚.
    • Slide the pick along the front edge to release the clips securing the back cover to the frame.
  4. Lenovo Legion 5 15ACH6H Battery Replacement, Release the left clips: paso 4, imagen 1 de 2 Lenovo Legion 5 15ACH6H Battery Replacement, Release the left clips: paso 4, imagen 2 de 2
    • Insert the edge of an opening pick between the back cover and the frame on the right edge.
    • Angle the pick to about 30˚ and slide down the left edge to release the clips.
  5. Lenovo Legion 5 15ACH6H Battery Replacement, Release the right clips: paso 5, imagen 1 de 2 Lenovo Legion 5 15ACH6H Battery Replacement, Release the right clips: paso 5, imagen 2 de 2
    • Repeat the same procedure on the left edge to release the clips.
  6. Lenovo Legion 5 15ACH6H Battery Replacement, Release the right vent clips: paso 6, imagen 1 de 3 Lenovo Legion 5 15ACH6H Battery Replacement, Release the right vent clips: paso 6, imagen 2 de 3 Lenovo Legion 5 15ACH6H Battery Replacement, Release the right vent clips: paso 6, imagen 3 de 3
    • Position the laptop vertically so you can easily access the plastic vents.
    • Slide the rounded edge of an opening pick between the frame and the plastic vents on the left side near the USB-C port.
    • Rotate the pick so that it is positioned on top of the plastic vents.
  7. Lenovo Legion 5 15ACH6H Battery Replacement: paso 7, imagen 1 de 2 Lenovo Legion 5 15ACH6H Battery Replacement: paso 7, imagen 2 de 2
    • Push the pick between the frame and plastic vents.
    • Slide the pick along the top edge of the plastic vents to release the clips.
  8. Lenovo Legion 5 15ACH6H Battery Replacement, Release the left vent clips: paso 8, imagen 1 de 3 Lenovo Legion 5 15ACH6H Battery Replacement, Release the left vent clips: paso 8, imagen 2 de 3 Lenovo Legion 5 15ACH6H Battery Replacement, Release the left vent clips: paso 8, imagen 3 de 3
    • Slide the opening pick between the frame and the plastic vents on the right side near the USB-A port.
  9. Lenovo Legion 5 15ACH6H Battery Replacement: paso 9, imagen 1 de 2 Lenovo Legion 5 15ACH6H Battery Replacement: paso 9, imagen 2 de 2
  10. Lenovo Legion 5 15ACH6H Battery Replacement, Remove the back cover: paso 10, imagen 1 de 3 Lenovo Legion 5 15ACH6H Battery Replacement, Remove the back cover: paso 10, imagen 2 de 3 Lenovo Legion 5 15ACH6H Battery Replacement, Remove the back cover: paso 10, imagen 3 de 3
    • Lift the back cover up and remove it from the chassis.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
  11. Lenovo Legion 5 15ACH6H Battery Replacement, Disconnect the battery: paso 11, imagen 1 de 3 Lenovo Legion 5 15ACH6H Battery Replacement, Disconnect the battery: paso 11, imagen 2 de 3 Lenovo Legion 5 15ACH6H Battery Replacement, Disconnect the battery: paso 11, imagen 3 de 3
    • Use the pointed end of a spudger to push each side of the battery connector to loosen it.
  12. Lenovo Legion 5 15ACH6H Battery Replacement: paso 12, imagen 1 de 2 Lenovo Legion 5 15ACH6H Battery Replacement: paso 12, imagen 2 de 2
    • Use the flat end of a spudger to push out and disconnect battery cable.
  13. Lenovo Legion 5 15ACH6H Battery Replacement, Right SSD removal: paso 13, imagen 1 de 2 Lenovo Legion 5 15ACH6H Battery Replacement, Right SSD removal: paso 13, imagen 2 de 2
    • Use a Phillips screwdriver to remove the three 5.1 mm PH00 screws securing the right SSD shield to the motherboard.
    • During reassembly, make sure the hole on the top of the shield aligns with the post on the chassis.
  14. Lenovo Legion 5 15ACH6H Battery Replacement, Remove the SSD shield: paso 14, imagen 1 de 3 Lenovo Legion 5 15ACH6H Battery Replacement, Remove the SSD shield: paso 14, imagen 2 de 3 Lenovo Legion 5 15ACH6H Battery Replacement, Remove the SSD shield: paso 14, imagen 3 de 3
    • Grab the SSD shield and lift up to remove it.
  15. Lenovo Legion 5 15ACH6H Battery Replacement: paso 15, imagen 1 de 2 Lenovo Legion 5 15ACH6H Battery Replacement: paso 15, imagen 2 de 2
    • Use a Phillips screwdriver to remove the 2.7 mm PH1 screw securing the SSD to the motherboard.
    • The SSD will spring up to about 30˚ when the screw is removed.
  16. Lenovo Legion 5 15ACH6H Battery Replacement, Remove the right SSD: paso 16, imagen 1 de 3 Lenovo Legion 5 15ACH6H Battery Replacement, Remove the right SSD: paso 16, imagen 2 de 3 Lenovo Legion 5 15ACH6H Battery Replacement, Remove the right SSD: paso 16, imagen 3 de 3
    • Grip the edges of the SSD near the screw indent.
    • Gently pull to remove the SSD.
  17. Lenovo Legion 5 15ACH6H Battery Replacement, Unfasten the battery: paso 17, imagen 1 de 1
    • Use your Phillips screwdriver to remove the four 5.1 mm-long screws securing the battery.
  18. Lenovo Legion 5 15ACH6H Battery Replacement, Remove the battery: paso 18, imagen 1 de 2 Lenovo Legion 5 15ACH6H Battery Replacement, Remove the battery: paso 18, imagen 2 de 2
    • Remove the battery from its recess.
Conclusión
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Lenovo Legion answers community for help.
5 personas más completaron esta guía.
Clay Eickemeyer
Miembro Desde 09/19/22
67,402 Reputación
453 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
136 Miembros
17,430 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 15
Ultimos 7 días: 116
Ultimos 30 días: 488
Todo El Tiempo: 7,275
