Saltar al contenido principal
Lenovo Ideapad Gaming 3 15ACH6 Battery Replacement
Qué necesitas
  1. Lenovo Ideapad Gaming 3 15ACH6 Battery Replacement, Unfasten the lower case: paso 1, imagen 1 de 2 Lenovo Ideapad Gaming 3 15ACH6 Battery Replacement, Unfasten the lower case: paso 1, imagen 2 de 2
    • Use a Phillips screwdriver to remove the 10 screws securing the lower case:
    • Six 12 mm screws
    • Four 4.5 mm screws
  2. Lenovo Ideapad Gaming 3 15ACH6 Battery Replacement, Insert an opening pick: paso 2, imagen 1 de 2 Lenovo Ideapad Gaming 3 15ACH6 Battery Replacement, Insert an opening pick: paso 2, imagen 2 de 2
    • Insert an opening pick between the lower case and the chassis on the front right edge.
  3. Lenovo Ideapad Gaming 3 15ACH6 Battery Replacement, Release the clips: paso 3, imagen 1 de 3 Lenovo Ideapad Gaming 3 15ACH6 Battery Replacement, Release the clips: paso 3, imagen 2 de 3 Lenovo Ideapad Gaming 3 15ACH6 Battery Replacement, Release the clips: paso 3, imagen 3 de 3
    • Slide the pick along the front edge to release the clips securing the lower case.
    • Continue sliding the opening pick along the left and right edges to release the remaining clips.
  4. Lenovo Ideapad Gaming 3 15ACH6 Battery Replacement, Remove the lower case: paso 4, imagen 1 de 3 Lenovo Ideapad Gaming 3 15ACH6 Battery Replacement, Remove the lower case: paso 4, imagen 2 de 3 Lenovo Ideapad Gaming 3 15ACH6 Battery Replacement, Remove the lower case: paso 4, imagen 3 de 3
    • Lift the lower case from the chassis and remove it.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
  5. Lenovo Ideapad Gaming 3 15ACH6 Battery Replacement, Disconnect the battery: paso 5, imagen 1 de 3 Lenovo Ideapad Gaming 3 15ACH6 Battery Replacement, Disconnect the battery: paso 5, imagen 2 de 3 Lenovo Ideapad Gaming 3 15ACH6 Battery Replacement, Disconnect the battery: paso 5, imagen 3 de 3
    • Use the pointed end of a spudger to push each side of the battery connector until it comes out of the socket.
  6. Lenovo Ideapad Gaming 3 15ACH6 Battery Replacement, Unfasten the battery: paso 6, imagen 1 de 1
    • Use your Phillips screwdriver to remove the four 5.6 mm-long screws securing the battery.
  7. Lenovo Ideapad Gaming 3 15ACH6 Battery Replacement, Remove the battery: paso 7, imagen 1 de 2 Lenovo Ideapad Gaming 3 15ACH6 Battery Replacement, Remove the battery: paso 7, imagen 2 de 2
    • Remove the battery from its recess.
Conclusión
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Lenovo IdeaPad answers community for help.
2 personas más completaron esta guía.
Clay Eickemeyer
Miembro Desde 09/19/22
67,336 Reputación
453 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
136 Miembros
17,430 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 12
Ultimos 7 días: 63
Ultimos 30 días: 295
Todo El Tiempo: 5,982
