Introducción
Use this guide to replace the battery in your HP 15 Laptop PC.
Note: This procedure was written using a model 15-dy2702dx HP 15 Laptop PC, but is fully compatible with any HP 15 Laptop PC whose model number starts with 15-dy or 15-ef.
Still under warranty? Contact HP to learn your warranty status, receive a repair under warranty if eligible, or for further warranty information.
This procedure requires removing the battery to disconnect it. Use care to avoid bending, twisting, or puncturing it—a charged lithium-ion battery can be very dangerous if accidentally punctured. If your battery looks puffy or swollen, take extra precautions.
Don't continue to use a damaged battery, as doing so is a potential safety hazard. If in doubt, replace it with a new battery.
Qué necesitas
Fully shut down your laptop and unplug all cables.
Use an opening pick to peel up an end of the front rubber foot until you can grip it with your fingers.
Use an opening pick to peel up an end of the rear rubber foot until you can grip it with your fingers.
Peel the rear foot away from the back cover and remove it.
Herramienta utilizada en este paso:Tesa 61395 Tape$5.99
The rear foot is thicker, with a deeper recess.
The front foot is thinner, with a shallower recess.
If you're reusing the rubber feet, the leftover adhesive should be tacky enough to reuse.
If the leftover adhesive isn't sticky enough or your replacement feet didn't come with adhesive, you can use double-sided tape such as Tesa Tape to secure the feet.
To install a foot, remove its adhesive liner, lay the foot into its matching recess, and press down firmly along the entire length of the foot to secure it.
Use a Phillips screwdriver to remove the eight screws securing the back cover:
Six 6.5 mm-long silver screws
Two 6.7 mm-long black screws
Insert the flat side of an opening pick into the seam between the top left edge of the back cover and the frame.
Slide the opening pick down to the bottom left corner to release the clips on the left edge.
Use a Phillips screwdriver to remove the five 3.7 mm-long screws securing the battery.
Gently lift the upper edge of the battery to disconnect its socket from the motherboard.
Remove the battery.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
For optimal performance, calibrate your newly installed battery after completing this guide.
Take your e-waste to an R2 or e-Stewards certified recycler. Depending on your region, used HP devices and parts can be returned for reuse or recycling through the HP Planet Partners program.
3 personas más completaron esta guía.
3 comentarios
The guide is fine, with one exception. It appears that the instructions for the rubber strips on the bottom are backwards. The deeper groove for the rubber strip is, in fact, in the back, not the front as stated. The shallower groove is in the front of the computer, not the back.
Thank you for the comment, the guide has been updated!
Thank you for the well written guide on replacing the battery on my almost 4 year old HP 15-EF laptop. The steps along with the pics. made it fairly simple and quick.
Cheers!
Ray L.
