Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 14 guías que incluyan este paso.
Traduciendo paso 8
Paso 8
Use tweezers to peel away any remaining adhesive from the phone's chassis. Then clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth to prep the surface for the new adhesive.
Peel the adhesive backing off of the new rear glass, carefully line up one edge of the glass against the phone chassis, and firmly press the glass onto the phone.
[* icon_reminder] To [* black] [* black] Then, [* black] Peel the adhesive backing off of the new rear glass, carefully line up one edge of the glass against the phone chassis, and firmly press the glass onto the phone. [* icon_reminder] [guide|124003|Follow this guide|new_window=true] to reinstall the old back cover, or to install a back cover without pre-installed adhesive. [* icon_note] Be sure to turn on your phone and test your repair before installing new adhesive and resealing the phone. [* icon_note] Replacement adhesive comes in a pre-cut sheet to match the exact contours of the back cover. If that's not available, you can use a high-bond double-sided tape, such as [product|IF317-072|Tesa 61395|new_window=true]. Be aware that this leaves gaps that are vulnerable to liquid intrusion. [* black] After installing the rear cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond, such as by placing it under a stack of heavy books. |
[* icon_note] If desired, you may reinstall the back cover without replacing the adhesive. Remove any large chunks of adhesive that might prevent the back cover from sitting down flush. After installation, heat the back cover and apply pressure to secure it. It won't be waterproof, but the glue is usually more than strong enough to hold. |
[* icon_reminder] You may also need to transfer the camera bezel to your new part. If that's the case, follow our [guide|122484|camera bezel replacement guide|stepid=236006|new_window=true]. |
