Saltar al contenido principal
Dell Inspiron 600M Disk Drive Replacement
Inglés
Español
Traduciendo paso 1
Paso 1
Dell Inspiron 600M Disk Drive Replacement: paso 0, imagen 1 de 1
  • Rotate the computer so that it is upside down and you are facing the rear panel with all the connection ports (You can base your position from the battery location in the image).
Gire la computadora de modo que esté al revés y esté mirando hacia el panel trasero con todos los puertos de conexión.
-[* black] Rotate the computer so that it is upside down and you are facing the rear panel with all the connection ports.
+[* black] Rotate the computer so that it is upside down and you are facing the rear panel with all the connection ports (You can base your position from the battery location in the image).
