Saltar al contenido principal
Dell Inspiron 600M Disk Drive Replacement
Inglés
Español
Traduciendo paso 2
Paso 2
Dell Inspiron 600M Disk Drive Replacement: paso 0, imagen 1 de 3 Dell Inspiron 600M Disk Drive Replacement: paso 0, imagen 2 de 3 Dell Inspiron 600M Disk Drive Replacement: paso 0, imagen 3 de 3
  • Using #00 screwdriver, unscrew the locking screw circled in red.
  • Push in on button directly beneath screw (where the finger is in the image). A tab should pop out as shown in picture 2.
  • Pull out on tab to remove disk drive.
  • Replace old disk drive with new disk drive and go through all steps in reverse to reassemble laptop.
Con #00 destornillador, destornille el tornillo de fijación.
Presione el botón directamente debajo del tornillo. Una lengüeta debe aparecer como se muestra en la imagen 2.
Tire de la lengüeta para quitar la unidad de disco.
-[* red] Using #00 screwdriver, unscrew locking screw.
-[* black] Push in on button directly beneath screw. A tab should pop out as shown in picture 2.
+[* red] Using #00 screwdriver, unscrew the locking screw circled in red.
+[* black] Push in on button directly beneath screw (where the finger is in the image). A tab should pop out as shown in picture 2.
[* black] Pull out on tab to remove disk drive.
+[* black] Replace old disk drive with new disk drive and go through all steps in reverse to reassemble laptop.
