Traduciendo paso 1
Paso 1
Unscrew the Cover
Unscrew the front of the casing by unscrewing the two 8mm screws indicated. We will be using a PH00 screwdriver for every screw in this guide.
You may or may not have to take the screw covers off beforehand. They’re easy to remove; all you have to do is pry them off. We used tweezers, but anything thin enough should work. Then, just unscrew the underlying screws.
[title] Unscrew the Cover | |
[* black] Unscrew the front of the casing by unscrewing the two 8mm screws indicated. We will be using a PH00 screwdriver for every screw in this guide. | |
- | [* black] You may or may not have to take the screw covers off beforehand. They’re easy to remove; all you have to do is pry them off. We used tweezers, but anything thin enough should work. Then, just unscrew the underlying screws. |
+ | [* black] You may or may not have to take the screw covers off beforehand. They’re easy to remove; all you have to do is pry them off. We used [product|IF145-020|tweezers], but anything thin enough should work. Then, just unscrew the underlying screws. |
