Saltar al contenido principal
Reconocimiento y desconexión de conectores de cable
Inglés
Español
Paso 6
Recognizing & Disconnecting Cable Connectors, Press Connectors: paso 0, imagen 1 de 3 Recognizing & Disconnecting Cable Connectors, Press Connectors: paso 0, imagen 2 de 3 Recognizing & Disconnecting Cable Connectors, Press Connectors: paso 0, imagen 3 de 3
Press Connectors
  • Press (or "pop") connectors are found at the end of a ribbon cable and have a flat, metal or plastic top—typically rectangular. These connectors are extremely common in smartphones and laptops, and connect a wide variety of small to medium-sized cables—screen, battery, board interconnect, etc.
  • Place a spudger or an opening tool under the connector's edge and pry straight up to disconnect it.
  • Make sure to pry under the edge of the connector itself, and not under the socket on the board. Otherwise, you risk permanently damaging the socket.
  • Work carefully: don't pry on or accidentally scrape any small, surface mounted components on the board.
  • Although more rare, some larger pop-style connectors might have a built-in pull-tab for easy disconnection. Lift straight up to disconnect these.
  • To reconnect, align the connector carefully over its socket and press down with your fingertip—first on one of the short sides, then the other—until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
  • Don't press down on the middle of wider connectors until they're fully seated. If misaligned, the connector or the pins underneath can bend or break, causing permanent damage.
Los conectores de presión (o "pop") se encuentran en el extremo de un cable plano y tienen una parte superior plana de metal o plástico, generalmente rectangular. Estos conectores son extremadamente comunes en smartphones y portátiles, y conectan una amplia variedad de cables pequeños y medianos: pantalla, batería, interconexión de placa, etc.
Coloca un spudger o una herramienta de apertura debajo del borde del conector y haz palanca hacia arriba para desconectarlo.
Asegúrate de hacer palanca debajo del borde del conector y no debajo del zócalo de la placa. De lo contrario, corres el riesgo de dañar permanentemente el enchufe.
Trabaja con cuidado: no haz palanca ni raspes accidentalmente ningún componente pequeño montado en la superficie del tablero.
Aunque son más raros, algunos conectores estilo pop más grandes pueden tener una lengüeta incorporada para una fácil desconexión. Levanta hacia arriba para desconectarlos.
Para volver a conectarlo, alinea el conector con cuidado sobre su zócalo y presiona hacia abajo con la punta del dedo primero en uno de los lados cortos, luego en el otro, hasta que encaje en su lugar. No intentes forzar el conector para colocarlo en su lugar. Si tienes problemas, vuelve a colocarlo e inténtelo de nuevo.
No presiones el centro de los conectores más anchos hasta que estén completamente asentados. Si está desalineado, el conector o las clavijas que se encuentran debajo pueden doblarse o romperse, provocando daños permanentes.
