Saltar al contenido principal
Reconocimiento y desconexión de conectores de cable
Inglés
Español
Paso 5
Recognizing & Disconnecting Cable Connectors, Flat-Topped (Low Profile) Connectors: paso 0, imagen 1 de 3 Recognizing & Disconnecting Cable Connectors, Flat-Topped (Low Profile) Connectors: paso 0, imagen 2 de 3 Recognizing & Disconnecting Cable Connectors, Flat-Topped (Low Profile) Connectors: paso 0, imagen 3 de 3
  • Some connectors have a flat, plastic top that sits flush on top of their socket. Often, these connectors have multiple cables connected to them. Flat-topped connectors are usually on the larger side, and are typically used to connect batteries in laptops and larger gaming devices.
  • To disconnect the cable, use the flat end of a spudger to lift and unclip the outer edges of the connector. You may need to use your fingers to pull the connector completely out of its socket.
  • Sometimes, these connectors have a slide lock running across the top that holds the connector in place. If this is the case, push the lock away from the connector before trying to disconnect it.
  • Flat topped connectors can also have a metal locking bar that keeps the connector in place. Unclip and flip the locking bar up to disconnect it.
  • To reconnect the cable, carefully position the connector over its socket and press straight down—the connector should snap into place without much force. If you're having trouble, the connector is most likely misaligned. Reposition it and try again.
  • Don't try to force the connector into place or you may damage the delicate pins.
Algunos conectores tienen una parte superior plana de plástico que se coloca al ras de su zócalo. A menudo, estos conectores tienen varios cables conectados a ellos. Los conectores con parte superior plana suelen ser de mayor tamaño y se utilizan normalmente para conectar baterías en ordenadores portátiles y dispositivos de juego de mayor tamaño.
Para desconectar conectores planos como este, usa una herramienta para levantar cada lado. Luego, levanta el conector directamente de su zócalo.
A veces, estos conectores tienen un bloqueo deslizante en la parte superior que mantiene el conector en su lugar. Si este es el caso,empuja el bloqueo hacia afuera del conector antes de intentar desconectarlo.
Los conectores de parte superior plana también pueden tener una barra de bloqueo de metal que mantiene el conector en su lugar. Suelta y levanta la barra de bloqueo para desconectarla.
Para volver a conectar el cable, coloca con cuidado el conector sobre su zócalo y presiona hacia abajo; el conector debe encajar en su lugar sin mucha fuerza. Si tienes problemas, lo más probable es que el conector esté desalineado. Vuelve a colocarlo e inténtelo de nuevo.
No intentes forzar el conector en su lugar o podrías dañar las delicadas clavijas.
