Traduciendo paso 4
Paso 4
Other Ribbon Cable Connectors
To disconnect this connector, use a spudger or clean fingernail to lift the looped tab away from the connector.
Then, use the tip of the spudger to push the plastic locking tab away from the socket—it should only move about 1–2 mm.
You can now pull the cable straight out of its socket.
Fully insert the cable into its socket under the locking tab.
Loop the tab around the front of the connector.
Use a spudger or clean fingernail to push in the locking tab, securing the cable.
