Saltar al contenido principal
Samsung Induction Cooktop NE63B8211SS Right Power Inverter Replacement
Inglés
Español
Paso 11
Samsung Induction Cooktop NE63B8211SS Right Power Inverter Replacement, Remove the Inverter: paso 0, imagen 1 de 2 Samsung Induction Cooktop NE63B8211SS Right Power Inverter Replacement, Remove the Inverter: paso 0, imagen 2 de 2
Remove the Inverter
  • At this step, you can double check that it is in fact your inverter that is bad. There may be an obvious sign, like a scorch mark on the PCB.
  • Once certain the inverter is the issue, there are four remaining harness points to unplug.
  • Once the harnesses are unplugged, remove the four screws keeping the board fixed in place.
  • There are two plastic pins that further secure the inverter. Take a pair of pliers to squeeze these down and gently lift the board off the housing.
Insertar traducción aquí
