Saltar al contenido principal
Samsung Induction Cooktop NE63B8211SS Right Power Inverter Replacement
Inglés
Español
Paso 10
Samsung Induction Cooktop NE63B8211SS Right Power Inverter Replacement, Remove Fan: paso 0, imagen 1 de 2 Samsung Induction Cooktop NE63B8211SS Right Power Inverter Replacement, Remove Fan: paso 0, imagen 2 de 2
Remove Fan
  • The fan for the right inverter keeps the inverter locked in place. Removing this will allow you to remove the inverter.
  • The fan housing has clips to keep the wires tight to the frame. Gently remove the wires from the clips before fan removal as they are easily broken.
  • Remove the two screws and disconnect the power from the PCB. Once completed, lift the fan out of the housing.
  • Once the fan is removed, remove the screws attaching the housing to the assay. Be sure to also lift the wire out of side clip before removing the plastic housing.
Insertar traducción aquí
