Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 12 guías que incluyen este paso.
Traduciendo paso 20
Use the pull tabs to remove the liners covering the front camera cutout, the rear camera pad, the back of the screen, and the perimeter adhesive.
Reconnect the screen cable and reinstall its cover.
This is a good point to test your phone before sealing it up. Temporarily power on your phone and make sure it works as expected. Power it down before continuing.
Firmly press the screen into place on the frame. You should feel the clips "pop" into place.
Press firmly around the perimeter of the screen to secure it with the new adhesive.
Follow this guide to calibrate the fingerprint sensor.
- | [title] Remove the screen |
- | [* black] Remove the screen. |
- | [* icon_reminder] During reassembly: |
- | [* black] If you replaced your screen, check the front-facing camera hole on your replacement screen and remove any remaining liners. |
- | [* icon_note] ***Remember to reinstall the screen cable cover.*** |
- | [* black] This is a good point to test your phone before sealing it up. Temporarily connect your screen, power on your phone, and make sure it works as expected. Before continuing with reassembly, ***power off your phone and disconnect the screen***. |
- | [* black] Follow [guide|166235|this guide|new_window=true] to replace your screen adhesive. |
- | [* black] If you're installing a new screen, follow [guide|166753|this guide|new_window=true] to calibrate the fingerprint sensor. |
+ | [title] Reassembly information |
+ | [* icon_note] If you're installing a new screen with pre-installed adhesive, follow this step during reassembly. Otherwise, follow [guide|166235|this guide|new_window=true] to apply adhesive to your old screen. |
+ | [* red] Use the pull tabs to remove the liners covering the front camera cutout, the rear camera pad, the back of the screen, and the perimeter adhesive. |
+ | [* black] Reconnect the screen cable and reinstall its cover. |
+ | [* black] This is a good point to test your phone before sealing it up. Temporarily power on your phone and make sure it works as expected. Power it down before continuing. |
+ | [* black] Firmly press the screen into place on the frame. You should feel the clips "pop" into place. |
+ | [* black] Press firmly around the perimeter of the screen to secure it with the new adhesive. |
+ | [* icon_note] Optionally, you can strengthen the adhesive bond by [guide|166235|applying pressure evenly to the phone|stepid=349905|new_window=true]. |
+ | [* black] Follow [guide|166753|this guide|new_window=true] to calibrate the fingerprint sensor. |
