Saltar al contenido principal
Google Pixel 8 Pro Screen Replacement
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 14 guías que incluyen este paso.
Inglés
Holandés
Traduciendo paso 21
Paso 21
Google Pixel 8 Pro Screen Replacement, Reassembly information: paso 0, imagen 1 de 3 Google Pixel 8 Pro Screen Replacement, Reassembly information: paso 0, imagen 2 de 3 Google Pixel 8 Pro Screen Replacement, Reassembly information: paso 0, imagen 3 de 3
  • If you're installing a new screen with pre-installed adhesive, follow this step during reassembly. Otherwise, follow this guide to apply adhesive to your old screen.
  • Thoroughly check the entire screen for any plastic liners or tape and use the pull tabs to remove all of them. Look carefully for a large piece of plastic covering the back of the screen, a small one near the front camera cutout, and adhesive liners around the perimeter.
  • Reconnect the screen cable and reinstall its cover.
  • This is a good point to test your phone before sealing it up. Temporarily power on your phone and make sure it works as expected. Power it down before continuing.
  • Firmly press the screen into place on the frame—you should feel the clips "pop" into place.
  • Press firmly around the perimeter of the screen to secure it with the new adhesive.
  • Optionally, you can strengthen the adhesive bond by applying pressure evenly to the phone.
  • Follow this guide to calibrate the fingerprint sensor.
Insertar traducción aquí
