Traduciendo paso 2
Paso 2
Remove the battery adhesive
Use blunt nose tweezers or your fingers to peel each stretch-release pull tab away from the battery.
Slowly pull the strips straight away from the battery, keeping a low angle to the frame.
Give the strips plenty of time to stretch. If a strip breaks off, try to retrieve it and continue pulling.
If you removed all 12 stretch-release adhesive strips, skip down three steps.
If any strips broke off, follow the next two steps for an alternative method to remove the battery.
[title] Remove the battery adhesive | |
- | [* black] Use blunt nose tweezers or your fingers to peel each stretch-release pull tab away from the battery. |
+ | [* black] Use blunt nose [product|IF145-020|tweezers] or your fingers to peel each stretch-release pull tab away from the battery. |
[* black] Slowly pull the strips straight away from the battery, keeping a low angle to the frame. | |
[* black] Give the strips plenty of time to stretch. If a strip breaks off, try to retrieve it and continue pulling. | |
[* black] ***If you removed all 12 stretch-release adhesive strips***, skip [guide|156066|down three steps|stepid=326639]. | |
[* black] ***If any strips broke off***, follow the next two steps for an alternative method to remove the battery. |
