Saltar al contenido principal
Xbox Series X Vervanging van de middelste chassismodule
Aviso: Estás editando una guía de requisitos previos. Cualquier cambio que realices afectará a todas las 17 guías que incluyen este paso.
Inglés
Holandés
Paso 2
Xbox Series X Center Chassis Assembly Replacement: paso 0, imagen 1 de 2 Xbox Series X Center Chassis Assembly Replacement: paso 0, imagen 2 de 2
  • Use a pair of tweezers to pull up on the black plastic pull tab to disconnect the USB port cable.
  • Pull only on the pull tab, not the cable itself.
  • If the USB port cable feels adhered to the metal chassis, use an apply an iOpener or hair dryer to heat the cable. Depending on your model of Xbox, you may also need to slide an opening pick under the cable to separate the adhesive.
Gebruik een pincet om de zwarte, plastic treklip omhoog te trekken. Hiermee koppel je de kabel van de USB-poort los van het middelste chassis.
Trek de kabel enkel aan de treklip, en niet aan de kabel zelf, omhoog.
-[* black] Use a pair of tweezers to pull up on the black plastic pull tab to remove the USB port cable from the center chassis.
+[* black] Use a pair of tweezers to pull up on the black plastic pull tab to disconnect the USB port cable.
[* icon_caution] Pull only on the pull tab, not the cable itself.
+ [* icon_note] If the USB port cable feels adhered to the metal chassis, use an [guide|11677|apply an iOpener|new_window=true] or [guide|157348|hair dryer|new_window=true] to heat the cable. Depending on your model of Xbox, you may also need to slide an opening pick under the cable to separate the adhesive.
