Saltar al contenido principal
Samsung Galaxy S8 Plus Rear Camera Bezel Replacement
Inglés
Holandés
Paso 5
Samsung Galaxy S8 Plus Rear Camera Bezel Replacement: paso 0, imagen 1 de 2 Samsung Galaxy S8 Plus Rear Camera Bezel Replacement: paso 0, imagen 2 de 2
  • If your part did not come with pre-cut adhesive, use high-bond double-sided tape, such as Tesa 61395, or pieces of a pre-cut adhesive sheet to secure the camera bezel.
  • Cut pieces of tape to the appropriate size so they fit along the edges of the camera bezel. When in doubt, use a narrower size tape than you think you might need.
  • Use tweezers to apply the tape to the metal surface of the bezel, on the side where the camera lens cover protrudes.
  • Try to cover most of the metal surface of the bezel with tape. Avoid overlapping tape onto any plastic or glass areas.
Insertar traducción aquí
