卸下电池排线固定架上的2颗十字 #00 螺丝。
1颗2.9 mm螺丝
1颗2.2 mm螺丝
如要组装的话, 请按逆序操作一下步骤。
如要组装的话, 请按逆序操作一下步骤。
41 personas más completaron esta guía.
Un agradecimiento especial a estos traductores:
100%
Estos traductores nos están ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
11 comentarios
Does anyone know where the secondary cell antenna is located on the 6S, it's easily visible on the 6S plus.
Is it under the top wifi antenna, built into the board?
Or at step 41 removing a 'plastic clip' which I thought could be the gps antenna
I had a question about the last step. Mine Upper component cable appears to be attached to the brackets that hold it in place. They appear to have very small spot welds which i cannot remove. It looks like the new cable should wrap around the brackets with an adhesive but i cant seem to get the brackets off of the old cable. Why doesn't the new cable come with those brackets attached? Or was i supposed to order those as separate pieces?
Good guide. Should have mentioned that buying the replacement cable WITH the brackets and switch attached is necessary . I bought a cable without and could not remove the mute button. Then went and bought a cable WITH the brackets and everything went together well. Phone works just fine.
