Saltar al contenido principal
iPad Mini 6 Rear Camera Replacement
Qué necesitas
  1. iPad Mini 6 Rear Camera Replacement, Apply tape to a cracked screen: paso 1, imagen 1 de 3 iPad Mini 6 Rear Camera Replacement, Apply tape to a cracked screen: paso 1, imagen 2 de 3 iPad Mini 6 Rear Camera Replacement, Apply tape to a cracked screen: paso 1, imagen 3 de 3
    • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
    • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
  2. Aviso: los pasos 2-13 provienen de una guía que está marcada como "En progreso".
    iPad Mini 6 Rear Camera Replacement, Heat the bottom edge: paso 2, imagen 1 de 1
    • Completely power off your device before you begin.
    • Apply a heated iOpener to the bottom edge of the device for 90 seconds to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
  3. iPad Mini 6 Rear Camera Replacement, Screen removal information: paso 3, imagen 1 de 3 iPad Mini 6 Rear Camera Replacement, Screen removal information: paso 3, imagen 2 de 3 iPad Mini 6 Rear Camera Replacement, Screen removal information: paso 3, imagen 3 de 3
    • While you're waiting for the adhesive to loosen, note the following:
    • The areas at the top and bottom of the screen are sensitive to prying.
    • Don't insert a pick more than 3 mm to avoid damaging the screen.
    • There's a long circuit board attached to the screen that sits parallel to the left edge.
    • Don't insert a pick more than 1.5 mm to avoid damaging the circuit board.
    • The first two images are mirrored for demonstration purposes.
  4. iPad Mini 6 Rear Camera Replacement, Insert an opening pick: paso 4, imagen 1 de 3 iPad Mini 6 Rear Camera Replacement, Insert an opening pick: paso 4, imagen 2 de 3 iPad Mini 6 Rear Camera Replacement, Insert an opening pick: paso 4, imagen 3 de 3
    • Once the screen is warm to touch, apply a suction handle to the bottom edge of the screen and as close to the edge as possible.
    • Lift the screen with the suction handle to create a small gap between the screen and the frame.
    • Insert an opening pick into the gap between the frame and the screen.
    • Don't insert the pick more than 1.5 mm to avoid damaging the circuit board.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  5. iPad Mini 6 Rear Camera Replacement, Separate the bottom adhesive: paso 5, imagen 1 de 3 iPad Mini 6 Rear Camera Replacement, Separate the bottom adhesive: paso 5, imagen 2 de 3 iPad Mini 6 Rear Camera Replacement, Separate the bottom adhesive: paso 5, imagen 3 de 3
    • Slide the pick along the bottom edge of the device towards the bottom-right corner.
    • Leave the pick in to prevent the adhesive from resealing.
  6. iPad Mini 6 Rear Camera Replacement, Heat the right edge: paso 6, imagen 1 de 1
    • Apply a heated iOpener to the right edge of the device for 90 seconds to loosen the adhesive underneath.
  7. iPad Mini 6 Rear Camera Replacement, Separate the bottom-right corner adhesive: paso 7, imagen 1 de 3 iPad Mini 6 Rear Camera Replacement, Separate the bottom-right corner adhesive: paso 7, imagen 2 de 3 iPad Mini 6 Rear Camera Replacement, Separate the bottom-right corner adhesive: paso 7, imagen 3 de 3
    • Rotate the opening pick around the bottom-right corner of the device.
  8. iPad Mini 6 Rear Camera Replacement, Separate the remaining adhesive: paso 8, imagen 1 de 2 iPad Mini 6 Rear Camera Replacement, Separate the remaining adhesive: paso 8, imagen 2 de 2
    • Repeat the heating, slicing, and leaving opening picks for the remaining edges of the device.
    • When you slice near the front camera, don't insert the pick more than 1.5 mm to avoid damaging or smearing the camera.
  9. iPad Mini 6 Rear Camera Replacement, Reposition the screen: paso 9, imagen 1 de 3 iPad Mini 6 Rear Camera Replacement, Reposition the screen: paso 9, imagen 2 de 3 iPad Mini 6 Rear Camera Replacement, Reposition the screen: paso 9, imagen 3 de 3
    • If there's still resistance around the edges of the screen, use an opening pick to cut the adhesive again.
    • Don't try to remove the screen all the way yet; it's still connected to the frame by a flex cable.
    • With the bottom of the device facing you, pull the right edge of the screen up and towards the left edge of the device.
    • Rest the screen upside down and parallel to the frame before continuing.
    • Don't twist the screen or move it too far away from the frame to avoid damaging the flex cable.
  10. iPad Mini 6 Rear Camera Replacement, Unfasten the display cable bracket: paso 10, imagen 1 de 2 iPad Mini 6 Rear Camera Replacement, Unfasten the display cable bracket: paso 10, imagen 2 de 2
    • Use a Phillips #000 screwdriver to remove the five 1.2 mm-long screws securing the frame bracket to the frame.
  11. iPad Mini 6 Rear Camera Replacement, Remove the display cable bracket: paso 11, imagen 1 de 2 iPad Mini 6 Rear Camera Replacement, Remove the display cable bracket: paso 11, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Use tweezers, or your fingers, to remove the display cable bracket from the frame.
  12. iPad Mini 6 Rear Camera Replacement, Disconnect the display: paso 12, imagen 1 de 3 iPad Mini 6 Rear Camera Replacement, Disconnect the display: paso 12, imagen 2 de 3 iPad Mini 6 Rear Camera Replacement, Disconnect the display: paso 12, imagen 3 de 3
    • Use the flat end of a spudger to pry up and disconnect the display cable's two press connectors secured to the frame.
  13. iPad Mini 6 Rear Camera Replacement, Remove the screen: paso 13, imagen 1 de 2 iPad Mini 6 Rear Camera Replacement, Remove the screen: paso 13, imagen 2 de 2
    • Remove the screen from the frame.
  14. iPad Mini 6 Rear Camera Replacement, Disconnect the battery: paso 14, imagen 1 de 2 iPad Mini 6 Rear Camera Replacement, Disconnect the battery: paso 14, imagen 2 de 2
    • The the flat end of a spudger to pry up and disconnect the battery's press connector secured to the frame.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  15. iPad Mini 6 Rear Camera Replacement, Unfasten the rear camera shield: paso 15, imagen 1 de 2 iPad Mini 6 Rear Camera Replacement, Unfasten the rear camera shield: paso 15, imagen 2 de 2
    • Use a Phillips #000 screwdriver to remove the two 1.2 mm screws securing the rear camera shield to the frame.
  16. iPad Mini 6 Rear Camera Replacement, Remove the rear camera shield: paso 16, imagen 1 de 2 iPad Mini 6 Rear Camera Replacement, Remove the rear camera shield: paso 16, imagen 2 de 2
    • Use tweezers, or your fingers, to remove the rear camera shield.
  17. iPad Mini 6 Rear Camera Replacement, Disconnect the antenna: paso 17, imagen 1 de 2 iPad Mini 6 Rear Camera Replacement, Disconnect the antenna: paso 17, imagen 2 de 2
    • Use the tip of a spudger to pry up and disconnect the antenna's coaxial cable.
    • During reassembly, these can be tricky to reconnect. Hold each connector in place over its socket and press down with the flat end of a spudger. The connector should snap into place.
  18. iPad Mini 6 Rear Camera Replacement, Reposition the coaxial cable: paso 18, imagen 1 de 2 iPad Mini 6 Rear Camera Replacement, Reposition the coaxial cable: paso 18, imagen 2 de 2
    • Use tweezers, or your fingers, to pull the coaxial cable away from the frame, making sure to separate the tape keeping it in place.
  19. iPad Mini 6 Rear Camera Replacement, Disconnect the power button board: paso 19, imagen 1 de 2 iPad Mini 6 Rear Camera Replacement, Disconnect the power button board: paso 19, imagen 2 de 2
    • Use the tip of a spudger to pry up and disconnect the power button board's press connector.
  20. iPad Mini 6 Rear Camera Replacement, Reposition the power button board's cable: paso 20, imagen 1 de 2 iPad Mini 6 Rear Camera Replacement, Reposition the power button board's cable: paso 20, imagen 2 de 2
    • The power button board's cable is lightly adhered to the rear camera's press connector.
    • Gently peel back on the power button board's cable to separate it from the rear camera's press connector.
  21. iPad Mini 6 Rear Camera Replacement, Disconnect the rear camera: paso 21, imagen 1 de 2 iPad Mini 6 Rear Camera Replacement, Disconnect the rear camera: paso 21, imagen 2 de 2
    • Use a spudger to pry up and disconnect the rear camera's press connector.
  22. iPad Mini 6 Rear Camera Replacement, Heat the rear camera: paso 22, imagen 1 de 1
    • Apply a heated iOpener to the top-right edge of the device for 1–2 minutes to loosen the rear camera's adhesive underneath.
  23. iPad Mini 6 Rear Camera Replacement, Separate the rear camera's adhesive: paso 23, imagen 1 de 3 iPad Mini 6 Rear Camera Replacement, Separate the rear camera's adhesive: paso 23, imagen 2 de 3 iPad Mini 6 Rear Camera Replacement, Separate the rear camera's adhesive: paso 23, imagen 3 de 3
    • Insert an opening pick between the rear camera and the frame.
    • Rotate the pick around the perimeter of the camera to separate all of the adhesive.
  24. iPad Mini 6 Rear Camera Replacement: paso 24, imagen 1 de 2 iPad Mini 6 Rear Camera Replacement: paso 24, imagen 2 de 2
    • Pry up with the opening pick to fully separate the rear camera from the frame.
    • If you're having trouble separating the adhesive, reapply the iOpener for 1–2 minutes and try again.
  25. iPad Mini 6 Rear Camera Replacement, Remove the rear camera: paso 25, imagen 1 de 1
    • Use tweezers, or your fingers, to remove the rear camera.
Conclusión
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad mini 6 Answers community for help.
Una persona más ha completado esta guía.
Alex Diaz-Kokaisl
Miembro Desde 01/16/22
163,762 Reputación
769 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
Miembros de 118
19,648 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 6
Ultimos 30 días: 36
Todo El Tiempo: 854
