Introducción
Use this guide to replace a worn out or dead battery in a SteelSeries Stratus Duo controller.
For your safety, discharge the battery below 25% before disassembling your controller. This reduces the risk of fire if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
You’ll need replacement adhesive when reassembling your device.
Qué necesitas
Use your fingers to remove the sticker located on the back cover of the Stratus Duo.
Use a Y0 Tri-point screwdriver to remove the five 9.3 mm-long screws securing the back cover.
Carefully lift the back cover assembly away from the frame and move it downward to uncover the battery cable and the interconnect cable at the top of the motherboard.
Using the pointed end of a spudger, push the grey tabs on the interconnect socket away from the socket, parallel to the interconnect cable, to release the cable.
Use a pair of blunt nose tweezers to grab and lift the connector away from the motherboard.
Insert the long edge of an opening pick into the gap between the battery and the back cover assembly.
Use the opening pick to carefully pry up the battery and separate the adhesive.
Grab the battery with your fingers and lift it out of its recess to remove it.
For optimal performance, calibrate your newly installed battery after completing this guide.
