Saltar al contenido principal
Steam Deck OLED Right Touchpad Replacement
Qué necesitas
  1. Steam Deck OLED Right Touchpad Replacement, Prepare your Steam Deck for disassembly: paso 1, imagen 1 de 3 Steam Deck OLED Right Touchpad Replacement, Prepare your Steam Deck for disassembly: paso 1, imagen 2 de 3 Steam Deck OLED Right Touchpad Replacement, Prepare your Steam Deck for disassembly: paso 1, imagen 3 de 3
    • Turn on your Steam Deck and allow the battery to discharge below 25% before starting your repairs, as a charged lithium-ion polymer battery can be dangerous if accidentally punctured.
    • As an extra precaution, Valve recommends putting your Steam Deck into battery storage mode within the BIOS before starting any internal repairs. Read how to do that here.
    • Power down your Steam Deck and unplug any cables.
    • If you have a microSD card installed, make sure to remove it before opening the Steam Deck. If you attempt to remove the back cover with it still installed, it could snap right in half.
    • During your repair, it can be helpful at times to lay the Steam Deck face-down in its case to protect the thumbsticks and prevent wobble.
  2. Steam Deck OLED Right Touchpad Replacement, Remove the back cover screws: paso 2, imagen 1 de 2 Steam Deck OLED Right Touchpad Replacement, Remove the back cover screws: paso 2, imagen 2 de 2
    Herramienta utilizada en este paso:
    FixMat
    $36.95
    Comprar
    • Use a T6 Torx driver to remove the eight 5.8 mm‑long screws securing the back cover.
  3. Steam Deck OLED Right Touchpad Replacement, Unclip a handle: paso 3, imagen 1 de 3 Steam Deck OLED Right Touchpad Replacement, Unclip a handle: paso 3, imagen 2 de 3 Steam Deck OLED Right Touchpad Replacement, Unclip a handle: paso 3, imagen 3 de 3
    • Insert an opening pick at an upward angle between the back cover and the front shell near one of the triggers.
    • If you can't insert your pick here, try along the top or bottom edges of the Steam Deck OLED before sliding it toward the handle.
    • Slide your pick along the edge of the handle to release the clips securing it to the front shell.
  4. Steam Deck OLED Right Touchpad Replacement, Unclip the top and bottom edges: paso 4, imagen 1 de 3 Steam Deck OLED Right Touchpad Replacement, Unclip the top and bottom edges: paso 4, imagen 2 de 3 Steam Deck OLED Right Touchpad Replacement, Unclip the top and bottom edges: paso 4, imagen 3 de 3
    • Reinsert your pick and slide it along the top and bottom edges until the back cover feels loose.
  5. Steam Deck OLED Right Touchpad Replacement, Remove the back cover: paso 5, imagen 1 de 3 Steam Deck OLED Right Touchpad Replacement, Remove the back cover: paso 5, imagen 2 de 3 Steam Deck OLED Right Touchpad Replacement, Remove the back cover: paso 5, imagen 3 de 3
    • Grip the unclipped handle and pull it away from the front shell to release the remaining clips.
    • Remove the back cover.
  6. Steam Deck OLED Right Touchpad Replacement, Disconnect the battery: paso 6, imagen 1 de 3 Steam Deck OLED Right Touchpad Replacement, Disconnect the battery: paso 6, imagen 2 de 3 Steam Deck OLED Right Touchpad Replacement, Disconnect the battery: paso 6, imagen 3 de 3
    • Grip the battery cable pull tab, located to the left of the battery.
    • Firmly pull the battery cable straight away from the motherboard shield (toward the battery) to disconnect it.
    • This bundled cable is fairly stiff. If you're having trouble, re-grip the pull tab close to the head of the connector and gently walk it side-to-side as you pull.
    • If the cable pull-tab feels fragile or rips during this process, remove the motherboard shield and disconnect the cable using a spudger.
    • When the battery cable comes free, it might push up on the motherboard shield. Don't worry, as this won't damage anything.
  7. Steam Deck OLED Right Touchpad Replacement, Reassembly instructions: paso 7, imagen 1 de 2 Steam Deck OLED Right Touchpad Replacement, Reassembly instructions: paso 7, imagen 2 de 2
    • During disassembly, skip the next three steps.
    • During reassembly:
    • Reinstall the two 3.8 mm‑long screws to secure the motherboard shield.
    • Reconnect the interconnect cable ZIF connector.
  8. Steam Deck OLED Right Touchpad Replacement, Reassembly instructions: paso 8, imagen 1 de 3 Steam Deck OLED Right Touchpad Replacement, Reassembly instructions: paso 8, imagen 2 de 3 Steam Deck OLED Right Touchpad Replacement, Reassembly instructions: paso 8, imagen 3 de 3
    • Use the flat end of a spudger to slide the battery connector into its socket on the motherboard.
  9. Steam Deck OLED Right Touchpad Replacement, Reassembly instructions: paso 9, imagen 1 de 3 Steam Deck OLED Right Touchpad Replacement, Reassembly instructions: paso 9, imagen 2 de 3 Steam Deck OLED Right Touchpad Replacement, Reassembly instructions: paso 9, imagen 3 de 3
    • During reassembly, follow this step and the above three steps to reconnect the battery.
    • Use your T6 Torx driver to remove the two 3.8 mm‑long screws securing the motherboard shield.
    • Lift the top edge of the motherboard shield up and flip it over the bottom edge of the frame, away from the motherboard.
    • Be careful not to crease or strain the cable.
  10. Steam Deck OLED Right Touchpad Replacement, Disconnect the right thumbstick: paso 10, imagen 1 de 3 Steam Deck OLED Right Touchpad Replacement, Disconnect the right thumbstick: paso 10, imagen 2 de 3 Steam Deck OLED Right Touchpad Replacement, Disconnect the right thumbstick: paso 10, imagen 3 de 3
    Comprar
    • Use the point of a spudger to flip up the small locking flap on the right thumbstick ZIF connector.
    • The pull tab on this connector may be labeled TS.
    • Use tweezers or your fingers to grip the cable's pull tab and slide the connector straight out of its socket to disconnect it.
  11. Steam Deck OLED Right Touchpad Replacement, Disconnect the interconnect cable: paso 11, imagen 1 de 3 Steam Deck OLED Right Touchpad Replacement, Disconnect the interconnect cable: paso 11, imagen 2 de 3 Steam Deck OLED Right Touchpad Replacement, Disconnect the interconnect cable: paso 11, imagen 3 de 3
    Comprar
    • Use a spudger to flip up the small white locking flap on the right button board interconnect cable ZIF connector.
    • The pull tab on this connector may be labeled C‑R.
    • Use tweezers or your fingers to grip the cable's pull tab and slide it straight out of its socket to disconnect it.
    • During reassembly, don't reconnect this cable yet. You'll reconnect it later.
  12. Steam Deck OLED Right Touchpad Replacement, Disconnect the right thumbstick: paso 12, imagen 1 de 3 Steam Deck OLED Right Touchpad Replacement, Disconnect the right thumbstick: paso 12, imagen 2 de 3 Steam Deck OLED Right Touchpad Replacement, Disconnect the right thumbstick: paso 12, imagen 3 de 3
    • Flip up the small black locking flap on the right thumbstick cable ZIF connector.
    • The pull tabs on the remaining ZIF connectors in this procedure may be labeled DB.
    • Slide the connector straight out of its socket to disconnect it.
  13. Steam Deck OLED Right Touchpad Replacement, Disconnect the right button board: paso 13, imagen 1 de 3 Steam Deck OLED Right Touchpad Replacement, Disconnect the right button board: paso 13, imagen 2 de 3 Steam Deck OLED Right Touchpad Replacement, Disconnect the right button board: paso 13, imagen 3 de 3
    • Flip up the small locking flap on the button board cable ZIF connector, located in the bottom left corner.
  14. Steam Deck OLED Right Touchpad Replacement, Disconnect the remaining ZIF connectors: paso 14, imagen 1 de 3 Steam Deck OLED Right Touchpad Replacement, Disconnect the remaining ZIF connectors: paso 14, imagen 2 de 3 Steam Deck OLED Right Touchpad Replacement, Disconnect the remaining ZIF connectors: paso 14, imagen 3 de 3
    • Repeat the ZIF cable disconnection procedure for the remaining three ZIF connectors:
    • The touchpad cable
    • The touchpad board cable
    • You may need to lift this cable as you pull to free its arms.
    • The action buttons and menu button cable
  15. Steam Deck OLED Right Touchpad Replacement, Disconnect the right haptics: paso 15, imagen 1 de 3 Steam Deck OLED Right Touchpad Replacement, Disconnect the right haptics: paso 15, imagen 2 de 3 Steam Deck OLED Right Touchpad Replacement, Disconnect the right haptics: paso 15, imagen 3 de 3
    • If you aren't replacing your button board, you can leave this cable connected and lay the board over the left side of the frame after you've removed the screws.
    • Be careful when disconnecting the haptics, as the cables and connector are very delicate. Pry only on the base of the white connector, and not on the cables or socket.
    • Insert the point of your spudger under the neck of the haptics cable connector.
    • Gently pry up to disconnect it.
  16. Steam Deck OLED Right Touchpad Replacement, Remove the right button board screws: paso 16, imagen 1 de 1
    • Use your T6 Torx driver to remove the four screws securing the right button board:
    • Two 5.9 mm‑long screws
    • One 3.8 mm‑long screw
    • One 4.9 mm‑long screw
  17. Steam Deck OLED Right Touchpad Replacement, Remove the right button board: paso 17, imagen 1 de 3 Steam Deck OLED Right Touchpad Replacement, Remove the right button board: paso 17, imagen 2 de 3 Steam Deck OLED Right Touchpad Replacement, Remove the right button board: paso 17, imagen 3 de 3
    • Insert the point of your spudger between the bottom left corner of the button board and the frame.
    • Pry up until you can grab the button board with your fingers.
    • Remove the button board.
    • During reassembly, make sure none of the six cables become trapped underneath the button board as you lay it into place.
  18. Steam Deck OLED Right Touchpad Replacement, Remove the right thumbstick screws: paso 18, imagen 1 de 2 Steam Deck OLED Right Touchpad Replacement, Remove the right thumbstick screws: paso 18, imagen 2 de 2
    • Use your T6 Torx driver to remove the three 5.9 mm‑long screws securing the right thumbstick.
    • During reassembly, hold the Steam Deck OLED off your work surface so it doesn't rest on your thumbstick as you tighten the screws.
  19. Steam Deck OLED Right Touchpad Replacement, Remove the right thumbstick: paso 19, imagen 1 de 3 Steam Deck OLED Right Touchpad Replacement, Remove the right thumbstick: paso 19, imagen 2 de 3 Steam Deck OLED Right Touchpad Replacement, Remove the right thumbstick: paso 19, imagen 3 de 3
    • Grip the edges of the thumbstick board and rotate it clockwise to clear the trigger.
    • Remove the thumbstick.
  20. Steam Deck OLED Right Touchpad Replacement, Remove the quick access button membrane: paso 20, imagen 1 de 2 Steam Deck OLED Right Touchpad Replacement, Remove the quick access button membrane: paso 20, imagen 2 de 2
    Comprar
    • Use tweezers to remove the quick access button membrane.
  21. Steam Deck OLED Right Touchpad Replacement, Remove the right touchpad board cable: paso 21, imagen 1 de 3 Steam Deck OLED Right Touchpad Replacement, Remove the right touchpad board cable: paso 21, imagen 2 de 3 Steam Deck OLED Right Touchpad Replacement, Remove the right touchpad board cable: paso 21, imagen 3 de 3
    • Flip up the small locking flap on the right touchpad board ZIF connector.
    • Lift the connector until its arms are free of the socket and slide it straight out to disconnect it.
  22. Steam Deck OLED Right Touchpad Replacement, Remove the touchpad board screws: paso 22, imagen 1 de 1
    • Use your T6 Torx driver to remove the four 5 mm‑long screws securing the touchpad board.
  23. Steam Deck OLED Right Touchpad Replacement, Remove the touchpad board: paso 23, imagen 1 de 2 Steam Deck OLED Right Touchpad Replacement, Remove the touchpad board: paso 23, imagen 2 de 2
    • Use your fingers to remove the touchpad board.
  24. Steam Deck OLED Right Touchpad Replacement, Remove the touchpad screws: paso 24, imagen 1 de 1
    • Use your T6 Torx driver to remove the four 6 mm‑long screws securing the touchpad.
  25. Steam Deck OLED Right Touchpad Replacement, Remove the touchpad: paso 25, imagen 1 de 3 Steam Deck OLED Right Touchpad Replacement, Remove the touchpad: paso 25, imagen 2 de 3 Steam Deck OLED Right Touchpad Replacement, Remove the touchpad: paso 25, imagen 3 de 3
    • Remove the touchpad.
    • If you're having trouble removing the touchpad, lift the edge of the Steam Deck OLED and push the touchpad through from the front.
Conclusión
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Steam Deck OLED answers community for help.
Clay Eickemeyer
Miembro Desde 09/19/22
69,485 Reputación
453 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
141 Miembros
17,892 Guías creadas
Un comentario
Where can the touchpads be bought from? Can't find them anywhere...
KirbyDaDragon - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 24
Ultimos 30 días: 107
Todo El Tiempo: 448
