Saltar al contenido principal
Samsung Galaxy S6 Edge Display Assembly and Frame Replacement
Qué necesitas
  1. Samsung Galaxy S6 Edge Display Assembly and Frame Replacement, Display assembly guide differentiation: paso 1, imagen 1 de 2 Samsung Galaxy S6 Edge Display Assembly and Frame Replacement, Display assembly guide differentiation: paso 1, imagen 2 de 2
  2. Samsung Galaxy S6 Edge Display Assembly and Frame Replacement, SIM Tray: paso 2, imagen 1 de 3 Samsung Galaxy S6 Edge Display Assembly and Frame Replacement, SIM Tray: paso 2, imagen 2 de 3 Samsung Galaxy S6 Edge Display Assembly and Frame Replacement, SIM Tray: paso 2, imagen 3 de 3
    • Insert a paper clip or SIM eject tool into the hole in the SIM card slot on top of the phone.
    • Do not insert the tool into the microphone hole or you could cause damage. Look for the outline of the SIM tray.
    • Press to eject the SIM card tray.
    • Remove the SIM card tray from the phone.
  3. Samsung Galaxy S6 Edge Display Assembly and Frame Replacement, iOpener Heating: paso 3, imagen 1 de 2 Samsung Galaxy S6 Edge Display Assembly and Frame Replacement, iOpener Heating: paso 3, imagen 2 de 2
    • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
    • Place the iOpener in the center of the microwave.
    • For carousel microwaves: Make sure the plate spins freely. If your iOpener gets stuck, it may overheat and burn.
  4. Samsung Galaxy S6 Edge Display Assembly and Frame Replacement: paso 4, imagen 1 de 1
    • Heat the iOpener for thirty seconds.
    • Depending on the wattage of your microwave, more or less time may be required. The iOpener is sufficiently heated when it's barely too hot to touch.
    • Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
    • Be careful not to overheat the iOpener during the repair. Overheating may cause the iOpener to burst. Do not attempt to heat over 100˚C (212˚F).
    • Never touch the iOpener if it appears swollen.
    • If the iOpener is still too hot in the middle to touch, continue using it while waiting for it to cool down some more before reheating. A properly heated iOpener should stay warm for up to 10 minutes.
  5. Samsung Galaxy S6 Edge Display Assembly and Frame Replacement: paso 5, imagen 1 de 1
    • Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
    • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
  6. Samsung Galaxy S6 Edge Display Assembly and Frame Replacement, Alternate iOpener heating method: paso 6, imagen 1 de 2 Samsung Galaxy S6 Edge Display Assembly and Frame Replacement, Alternate iOpener heating method: paso 6, imagen 2 de 2
    • If you don't have a microwave, follow this step to heat your iOpener in boiling water.
    • Fill a pot or pan with enough water to fully submerge an iOpener.
    • Heat the water to a boil. Turn off the heat.
    • Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
    • Use tongs to extract the heated iOpener from the hot water.
    • Thoroughly dry the iOpener with a towel.
    • The iOpener will be very hot, so be careful to hold it only by the end tabs.
    • Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
  7. Samsung Galaxy S6 Edge Display Assembly and Frame Replacement, Rear Glass: paso 7, imagen 1 de 2 Samsung Galaxy S6 Edge Display Assembly and Frame Replacement, Rear Glass: paso 7, imagen 2 de 2
    • Opening your phone will compromise its waterproof seals. Have replacement adhesive ready before you proceed, or take care to avoid liquid exposure if you reassemble your phone without replacing the adhesive.
    • If your glass is shattered, put packing tape over the entire panel to hold it together during the removal process.
    • Lay the heated iOpener over the rear panel for about two minutes to loosen the adhesive around the edge of the glass.
    • You may need to reheat and reapply the iOpener several times to get the phone warm enough. Follow the iOpener instructions to avoid overheating.
    • Shift the iOpener to heat the remaining section of the panel for another two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the OLED display and internal battery are both susceptible to heat damage.
  8. Samsung Galaxy S6 Edge Display Assembly and Frame Replacement: paso 8, imagen 1 de 3 Samsung Galaxy S6 Edge Display Assembly and Frame Replacement: paso 8, imagen 2 de 3 Samsung Galaxy S6 Edge Display Assembly and Frame Replacement: paso 8, imagen 3 de 3
    • Once the rear glass is hot to the touch, apply a suction cup near the bottom edge of the glass.
    • Lift on the suction cup to create a small gap underneath the rear glass, and insert an opening pick into the gap.
    • Optionally, once the pick is inserted, you can add a few drops of isopropyl alcohol into the gap to help weaken the adhesive in the following steps.
  9. Samsung Galaxy S6 Edge Display Assembly and Frame Replacement: paso 9, imagen 1 de 2 Samsung Galaxy S6 Edge Display Assembly and Frame Replacement: paso 9, imagen 2 de 2
    • Slide the pick along the bottom edge of the phone to slice through the adhesive securing the rear glass.
    • Afterward, it may help to leave the pick in place and grab a second pick as you proceed to the next step. Leaving the pick inserted can help prevent the glue you just separated from re-adhering.
    • Re-heat the rear glass as needed to prevent the glue from cooling and hardening.
  10. Samsung Galaxy S6 Edge Display Assembly and Frame Replacement: paso 10, imagen 1 de 3 Samsung Galaxy S6 Edge Display Assembly and Frame Replacement: paso 10, imagen 2 de 3 Samsung Galaxy S6 Edge Display Assembly and Frame Replacement: paso 10, imagen 3 de 3
    • Repeat the heating and cutting procedure for the remaining three sides of the phone.
    • Leave an opening pick under each edge to prevent the adhesive from resealing.
  11. Samsung Galaxy S6 Edge Display Assembly and Frame Replacement: paso 11, imagen 1 de 2 Samsung Galaxy S6 Edge Display Assembly and Frame Replacement: paso 11, imagen 2 de 2
    • Use an opening pick to slice through any remaining adhesive.
    • Remove the rear glass.
  12. Samsung Galaxy S6 Edge Display Assembly and Frame Replacement: paso 12, imagen 1 de 2 Samsung Galaxy S6 Edge Display Assembly and Frame Replacement: paso 12, imagen 2 de 2
    Herramienta utilizada en este paso:
    • To install new rear glass:
    • Use tweezers to peel away any remaining adhesive from the phone's chassis.
    • Clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth. Swipe in one direction only, not back and forth. This will help prep the surface for the new adhesive.
    • Peel the adhesive backing off of the new rear glass, carefully line up one edge of the glass against the phone chassis, and firmly press the glass onto the phone.
    • If you're reinstalling the old rear glass, or using rear glass without adhesive pre-installed, follow this guide.
  13. Samsung Galaxy S6 Edge Display Assembly and Frame Replacement, Midframe Assembly: paso 13, imagen 1 de 1
    • Remove the thirteen 3.3 mm Phillips #00 screws from the midframe.
  14. Samsung Galaxy S6 Edge Display Assembly and Frame Replacement: paso 14, imagen 1 de 3 Samsung Galaxy S6 Edge Display Assembly and Frame Replacement: paso 14, imagen 2 de 3 Samsung Galaxy S6 Edge Display Assembly and Frame Replacement: paso 14, imagen 3 de 3
    • Press down on the back of the battery and lift up on the edges of the midframe to separate it from the rest of the phone.
  15. Samsung Galaxy S6 Edge Display Assembly and Frame Replacement, Motherboard Removal: paso 15, imagen 1 de 2 Samsung Galaxy S6 Edge Display Assembly and Frame Replacement, Motherboard Removal: paso 15, imagen 2 de 2
    • Using the flat end of the spudger, disconnect the battery ribbon cable from the motherboard.
  16. Samsung Galaxy S6 Edge Display Assembly and Frame Replacement: paso 16, imagen 1 de 2 Samsung Galaxy S6 Edge Display Assembly and Frame Replacement: paso 16, imagen 2 de 2
    • Disconnect the home button ribbon cable from the motherboard.
  17. Samsung Galaxy S6 Edge Display Assembly and Frame Replacement: paso 17, imagen 1 de 3 Samsung Galaxy S6 Edge Display Assembly and Frame Replacement: paso 17, imagen 2 de 3 Samsung Galaxy S6 Edge Display Assembly and Frame Replacement: paso 17, imagen 3 de 3
    • Use the pointed end of a spudger to disconnect the two antenna interconnect cables from the motherboard.
  18. Samsung Galaxy S6 Edge Display Assembly and Frame Replacement: paso 18, imagen 1 de 2 Samsung Galaxy S6 Edge Display Assembly and Frame Replacement: paso 18, imagen 2 de 2
    • Disconnect the display ribbon cable from the motherboard using the flat end of the spudger.
  19. Samsung Galaxy S6 Edge Display Assembly and Frame Replacement: paso 19, imagen 1 de 2 Samsung Galaxy S6 Edge Display Assembly and Frame Replacement: paso 19, imagen 2 de 2
    • Disconnect the earpiece ribbon cable from the motherboard.
  20. Samsung Galaxy S6 Edge Display Assembly and Frame Replacement: paso 20, imagen 1 de 2 Samsung Galaxy S6 Edge Display Assembly and Frame Replacement: paso 20, imagen 2 de 2
    • The motherboard is an ESD sensitive component and should be handled with care. iFixit recommends using a anti-static bracelet whenever handling components of this nature to avoid damage.
    • Grip the motherboard on both edges toward the top of the device.
    • Do not lift the motherboard all the way out in this step; the ribbon cable on the underside needs to be disconnected first.
    • Lift the motherboard up and away from the display, taking care not to put too much stress on the daughterboard ribbon cable.
  21. Samsung Galaxy S6 Edge Display Assembly and Frame Replacement: paso 21, imagen 1 de 2 Samsung Galaxy S6 Edge Display Assembly and Frame Replacement: paso 21, imagen 2 de 2
    • Disconnect the daughterboard ribbon cable from the underside of the motherboard.
  22. Samsung Galaxy S6 Edge Display Assembly and Frame Replacement, Battery: paso 22, imagen 1 de 3 Samsung Galaxy S6 Edge Display Assembly and Frame Replacement, Battery: paso 22, imagen 2 de 3 Samsung Galaxy S6 Edge Display Assembly and Frame Replacement, Battery: paso 22, imagen 3 de 3
    • Insert an opening pick underneath the battery and slide it across to break up the adhesive underneath.
    • The center area underneath the battery has no frame reinforcement. Be careful not to damage the fragile exposed display panel when prying.
    • Try your best not to deform the battery while prying. Soft-shell lithium-ion batteries can leak dangerous chemicals, catch fire, or even explode if damaged. Do not use excessive force or pry at the battery with metal tools.
  23. Samsung Galaxy S6 Edge Display Assembly and Frame Replacement: paso 23, imagen 1 de 2 Samsung Galaxy S6 Edge Display Assembly and Frame Replacement: paso 23, imagen 2 de 2
    • Twist the opening pick to fully dislodge the battery and remove it.
    • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
    • To install a new battery and ensure that is is properly aligned:
    • Remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
    • Lay the replacement battery in place, but do not apply adhesive yet. Resume re-assembly until the motherboard is in place (STEP 18).
    • Apply new pre-cut adhesive or double-sided tape onto the phone frame, around the perimeter of the battery compartment, but not in the rectangular cutout in the center (which is actually the back side of the display).
    • Temporarily connect the battery connector to the motherboard to ensure proper battery alignment.
    • Press the battery firmly into place for 5-10 seconds. Disconnect the battery and resume re-assembly.
  24. Samsung Galaxy S6 Edge Display Assembly and Frame Replacement, Charging Port Daughterboard: paso 24, imagen 1 de 1
    • Remove the two 2.5mm Phillips #00 screws.
  25. Samsung Galaxy S6 Edge Display Assembly and Frame Replacement: paso 25, imagen 1 de 2 Samsung Galaxy S6 Edge Display Assembly and Frame Replacement: paso 25, imagen 2 de 2
    • Using the pointed end of spudger, pry up the small section of daughterboard secured with a light adhesive.
  26. Samsung Galaxy S6 Edge Display Assembly and Frame Replacement: paso 26, imagen 1 de 3 Samsung Galaxy S6 Edge Display Assembly and Frame Replacement: paso 26, imagen 2 de 3 Samsung Galaxy S6 Edge Display Assembly and Frame Replacement: paso 26, imagen 3 de 3
    • Lift the daughterboard up and away from the body of the phone to remove it.
  27. Samsung Galaxy S6 Edge Display Assembly and Frame Replacement, Display Assembly and Frame: paso 27, imagen 1 de 3 Samsung Galaxy S6 Edge Display Assembly and Frame Replacement, Display Assembly and Frame: paso 27, imagen 2 de 3 Samsung Galaxy S6 Edge Display Assembly and Frame Replacement, Display Assembly and Frame: paso 27, imagen 3 de 3
    • Press the tip of a spudger in the gap in the display frame under the vibrator, to pry it off the adhesive.
    • Remove the vibrator from the display assembly.
    • Compare your replacement part to the display assembly that remains, you may need to transfer additional components such as the display frame or home button.
Conclusión
To reassemble your device, follow these instructions in reverse order. Follow this guide to reinstall the rear glass.
66 personas más completaron esta guía.
Sam Goldheart
Miembro Desde 10/18/12
472,011 Reputación
538 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
Miembros de 121
19,763 Guías creadas
6Guía Comentarios
Would it be possible to point out which connectors are for the LCD/touch screen, as my screen is not broken but part of the my touch screen will not work and I would like to check the connector is applied properly. Also would it be possible to purchase that suction cup somewhere?
Nina Borseth - Contestar
It does not seem as though steps #25, #26, and #27 are necessary for this specific project: Display Assembly Replacement. Otherwise an excellent guide!
Liam K - Contestar
You are right! The guide has been re-organized to leave those steps out now.
Arthur Shi -
Does anybody know if there is actually any difference between the CDMA and GSM screens? I got a galaxy s6 edge with a broken screen, and the back said verizon, but when I opened it up, the charging port flex cable said, SM-G925A, which is the AT&T version right? I have a working screen I took off of a working verizon phone, but it doesn’t work on the ATT phone. I’m not sure if its that the motherboard is damaged, or if the Verizon screen won’t work on the AT&T phone.
Reed Deemer - Contestar
I have samsung s7 edge
A-Z GADGET - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 40
Todo El Tiempo: 62,080
