Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Ryobi CSB125 Protective Shell Replacement
Qué necesitas
    1. Ryobi CSB125 Protective Shell Replacement, Protective Shell: paso 1, imagen 1 de 1
      • Place the saw on a flat surface with the blade facing up.
      • Make sure that the saw is unplugged from any power source.
      Pregunta a FixBot
      Agregar Comentario
    2. Ryobi CSB125 Protective Shell Replacement: paso 2, imagen 1 de 1
      • Remove the bumper by using the T20 Torx screwdriver to loosen the M5 x 20mm screw.
      Pregunta a FixBot
      Agregar Comentario
    3. Ryobi CSB125 Protective Shell Replacement: paso 3, imagen 1 de 2 Ryobi CSB125 Protective Shell Replacement: paso 3, imagen 2 de 2
      • Use the 7”/32 allen key to loosen the 5/16-18 x 9/16 in. blade screw.
      Pregunta a FixBot
      Agregar Comentario
    4. Ryobi CSB125 Protective Shell Replacement: paso 4, imagen 1 de 1
      • Remove the 5/16-18 x 9/16 in. blade screw, spring washer, the outer blade washer, the blade, and the inner blade washer.
      Pregunta a FixBot
      Agregar Comentario
    5. Ryobi CSB125 Protective Shell Replacement: paso 5, imagen 1 de 3 Ryobi CSB125 Protective Shell Replacement: paso 5, imagen 2 de 3 Ryobi CSB125 Protective Shell Replacement: paso 5, imagen 3 de 3
      • Use the Phillips #2 screwdriver to remove the four M4x16mm screws shown.
      • You will need to rotate the protective shell around in order to access them.
      Pregunta a FixBot
      Agregar Comentario
    6. Ryobi CSB125 Protective Shell Replacement: paso 6, imagen 1 de 1
      • Remove the lower blade guard support assembly from the rest of the saw.
      • Remove the protective shell.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
4 personas más completaron esta guía.
Curtis Melo
Miembro Desde 10/31/19
1,093 Reputación
5 Guías creadas
Equipo
UMass Dartmouth, Team S2-G1, Barthe Fall 2019 Miembro de UMass Dartmouth, Team S2-G1, Barthe Fall 2019
UMASSD-BARTHE-F19S2G1
Miembros de 3
5 Guías creadas
4Guía Comentarios
Instructions fail at step #5. Bottom-left screw is under the plastic blade guard which blocks removal of the screw. Blade guard covers the screw no matter how it’s positioned.
Michael Bluejay - Contestar Compartir
If you wiggle the plastic you can remove
I was able to remove… be patient it does work
Adrian Isbister - Contestar Compartir
Instructions also fail at step #6. I have no idea how to remove the plastic blade guard from the axle so I can transfer it to the new (replacement) blade guard.
I also was struggling… … but if you look closely there is a thin metal ring around the center plastic ring that the spindle runs through… this has a split in it…. I used a small flat Precision screwdriver (type used to tighten reading glasses,etc)and was able to pry at the split and remove the thin metal ring.
Once removed this frees the plastic guard and it drops right out.
Just reverse to reassemble.
This works… just be patient
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 33
Todo El Tiempo: 2,838
