Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Parrot Skycontroller 2 Buttons Replacement
Qué necesitas
    1. Parrot Skycontroller 2 Buttons Replacement, Battery: paso 1, imagen 1 de 3 Parrot Skycontroller 2 Buttons Replacement, Battery: paso 1, imagen 2 de 3 Parrot Skycontroller 2 Buttons Replacement, Battery: paso 1, imagen 3 de 3
      • Flip your controller face down.
      Pregunta a FixBot
      Agregar Comentario
    2. Parrot Skycontroller 2 Buttons Replacement: paso 2, imagen 1 de 1
      • Remove one 9mm screw using a #4 flathead screwdriver.
      Pregunta a FixBot
      Agregar Comentario
    3. Parrot Skycontroller 2 Buttons Replacement: paso 3, imagen 1 de 3 Parrot Skycontroller 2 Buttons Replacement: paso 3, imagen 2 de 3 Parrot Skycontroller 2 Buttons Replacement: paso 3, imagen 3 de 3
      • Insert the plastic opening tool into the top of the cover and pry upwards to lift the battery cover.
      • Remove the cover by pulling up and out.
      Pregunta a FixBot
      Agregar Comentario
    4. Parrot Skycontroller 2 Buttons Replacement: paso 4, imagen 1 de 3 Parrot Skycontroller 2 Buttons Replacement: paso 4, imagen 2 de 3 Parrot Skycontroller 2 Buttons Replacement: paso 4, imagen 3 de 3
      • Pull the connectors out by gently pushing the tabs and pulling up on the connector.
      • Disconnect the battery from the remote by pressing the white tab and pulling the connectors apart.
      Pregunta a FixBot
      Agregar Comentario
    5. Parrot Skycontroller 2 Buttons Replacement: paso 5, imagen 1 de 2 Parrot Skycontroller 2 Buttons Replacement: paso 5, imagen 2 de 2
      • Remove the battery from its brackets by pulling up on the ends of the battery.
      Pregunta a FixBot
      Agregar Comentario
    1. Parrot Skycontroller 2 Buttons Replacement, Buttons: paso 6, imagen 1 de 1
      • Remove the seven black 11mm screws using the Torx TR6 screwdriver.
      • There is a hidden screw located behind the sticker in the battery compartment.
      • Pull back the sticker with your finger nail and remove the one black 11mm screw using the Torx TR6 screwdriver.
      Pregunta a FixBot
      Agregar Comentario
    2. Parrot Skycontroller 2 Buttons Replacement: paso 7, imagen 1 de 3 Parrot Skycontroller 2 Buttons Replacement: paso 7, imagen 2 de 3 Parrot Skycontroller 2 Buttons Replacement: paso 7, imagen 3 de 3
      • Remove the seven silver 4mm screws from around the edge of the top plate using the Torx TR6 Screwdriver.
      • The opposite side to the third picture has a screw located on each side of the USB port.
      Pregunta a FixBot
      Agregar Comentario
    3. Parrot Skycontroller 2 Buttons Replacement: paso 8, imagen 1 de 1
      • Remove the battery compartment plate by pulling up and out.
      Pregunta a FixBot
      Agregar Comentario
    4. Parrot Skycontroller 2 Buttons Replacement: paso 9, imagen 1 de 1
      • Remove the top plate by pushing on the corners with your hand.
      • Be careful to not pull too hard on the cable.
      Pregunta a FixBot
      Agregar Comentario
    5. Parrot Skycontroller 2 Buttons Replacement: paso 10, imagen 1 de 2 Parrot Skycontroller 2 Buttons Replacement: paso 10, imagen 2 de 2
      • Remove the face plate by pulling up and out.
      • Buttons will fall out when this plate is removed.
      Pregunta a FixBot
      Agregar Comentario
    6. Parrot Skycontroller 2 Buttons Replacement: paso 11, imagen 1 de 3 Parrot Skycontroller 2 Buttons Replacement: paso 11, imagen 2 de 3 Parrot Skycontroller 2 Buttons Replacement: paso 11, imagen 3 de 3
      • Use some force pull up and out on the rubber backing for the buttons.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 24
Todo El Tiempo: 654
