Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Nintendo GameCube Controller Buttons Replacement
Qué necesitas
  1. Nintendo GameCube Controller Buttons Replacement, Back Panel: paso 1, imagen 1 de 1
    • Place the controller (buttons down) on a solid surface.
    • Remove the six 9.2mm Tri-wing Y0 screws that hold the back panel in place.
    Pregunta a FixBot
    Agregar Comentario
  2. Nintendo GameCube Controller Buttons Replacement: paso 2, imagen 1 de 1
    • Gently lift the back panel up, separating it from the front panel.
    • Some of the buttons may fall out if they are knocked around.
    Pregunta a FixBot
    Agregar Comentario
  3. Nintendo GameCube Controller Buttons Replacement, Z Button: paso 3, imagen 1 de 2 Nintendo GameCube Controller Buttons Replacement, Z Button: paso 3, imagen 2 de 2
    • Grab the Z-button by the peg with tweezers and lift it out of the controller.
    • During re-assembly, make sure the plastic rim and spring fit into the slot provided, or else the case will not shut.
    Pregunta a FixBot
    Agregar Comentario
  4. Nintendo GameCube Controller Buttons Replacement, Circuit Board: paso 4, imagen 1 de 1
    • Carefully unhook the cable that is looped around the peg.
    Pregunta a FixBot
    Agregar Comentario
  5. Nintendo GameCube Controller Buttons Replacement: paso 5, imagen 1 de 1
    • Lift the circuit board out of the controller.
    • Do not grab the rumble motor to lift the circuit board as shown in the picture. It will in many cases just remove the rumble motor. Instead, grab the edges of the board.
    Pregunta a FixBot
    Agregar Comentario
  6. Nintendo GameCube Controller Buttons Replacement, Buttons: paso 6, imagen 1 de 2 Nintendo GameCube Controller Buttons Replacement, Buttons: paso 6, imagen 2 de 2
    • Remove the rubber backing that covers the buttons.
    Pregunta a FixBot
    Agregar Comentario
  7. Nintendo GameCube Controller Buttons Replacement: paso 7, imagen 1 de 3 Nintendo GameCube Controller Buttons Replacement: paso 7, imagen 2 de 3 Nintendo GameCube Controller Buttons Replacement: paso 7, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Use tweezers to lift buttons out of their sockets.
    • When putting the buttons back, make sure the slots properly fit back together.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
20 personas más completaron esta guía.
Sean Michel
Miembro Desde 01/14/13
2,750 Reputación
8 Guías creadas
Equipo
Cal Poly, Team 19-44, Regan Winter 2013 Miembro de Cal Poly, Team 19-44, Regan Winter 2013
CPSU-REGAN-W13S19G44
Miembros de 4
34 Guías creadas
3Guía Comentarios
Is there a way I can buy the buttons separably? I lost a the X button and it's gone missing and i wanna buy one :(
tp4yourbunghole - Contestar Compartir
u can either get a 2 dollar full button set on ebay by searching ngc buttons or u can buy from battle beaver customs for 1 dollar
dariuscorrfz - Contestar Compartir
How do you put the back back on?
Steven Enns - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 30
Ultimos 30 días: 190
Todo El Tiempo: 32,990
