Introducción
Use this guide to replace the display on your Motorola Moto G60S.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Note: This guide is for replacing the display panel itself. A display pre-installed into a new chassis requires a different procedure. Make sure you have the correct replacement part before beginning this guide.
You'll need replacement adhesive to complete this repair.
Qué necesitas
Insert a SIM eject tool, bit, or straightened paperclip into the SIM card tray hole on the left edge of the phone.
Push the SIM eject tool into the hole to eject the SIM card tray.
Remove the SIM card tray.
Heat an iOpener and apply it to the back cover's right edge for two minutes.
Flip your phone over so the display is facing up.
Apply a suction handle to the middle of the display's left edge, as close to the edge as possible.
Place the tip of an opening pick in the small gap between the back cover and the display.
Pull up on the suction cup with a strong, steady force and push the opening pick down at a 45 degree angle until it slides into the gap between the back cover and the display.
Slide the pick along the left edge down to the bottom left corner, and then up to the top left corner, to release the clips and slice the adhesive.
Leave the pick inserted in the top left corner to prevent the adhesive from resealing.
Flip your phone over and apply a heated iOpener to the back cover's top edge for two minutes.
Press down on the fingerprint sensor with the flat end of a spudger or your finger.
While pressing down on the fingerprint sensor, gently pull up the bottom edge of the back cover until the sensor detaches.
Lift the back cover up and remove it.
This is a good point to test your phone's functionality before sealing it up. Use this guide to run a hardware test. Be sure to power your phone back down completely before you continue working.
Apply new adhesive to the perimeter of the underside of the back cover after cleaning the relevant areas with isopropyl alcohol (>90%) and a micro-fiber cloth.
Insert the flat end of a spudger under the fingerprint sensor.
Gently pry up and detach the fingerprint sensor from the motherboard cover.
Use a Phillips screwdriver to remove the seven 3.9 mm screws securing the motherboard cover.
Insert the flat end of a spudger in the gap between the frame and the bottom left corner of the motherboard cover.
Lift straight up with the spudger to release the clips securing the motherboard.
Pull the motherboard cover towards the top of the phone to remove it.
Use the flat end of a spudger to pry up and disconnect the battery cable's press connector.
Insert the pointed end of a spudger under the graphite film on the left side of the daughterboard cover.
Lift up to peel the graphite film off of the battery.
Apply a few drops of high-concentration (90% or higher) isopropyl alcohol to the gaps along the battery's edges.
Tilt the device to help it flow under the battery.
Wait one minute to allow the isopropyl alcohol to penetrate the adhesive.
Apply a suction cup to middle of the battery.
Pull up on the suction cup with strong, steady force to separate the battery from the frame.
Continue to pull up on the suction cup while sliding the opening pick back and forth to slice the adhesive.
Continue this process until the battery separates from the frame, applying isopropyl alcohol as necessary.
Use your fingers to remove the foam strip from the old battery's bottom edge.
Apply the foam strip to the bottom edge of the replacement battery.
Use a spudger to pry up and disconnect the display's press connector.
Gently pull the display's ribbon cable up and towards the bottom of the phone until it's completely separated from the frame.
Place the back cover on the frame and press around the perimeter to engage the clips.
Flip your phone over.
Apply a heated iOpener to the display's top edge for two minutes.
Apply a suction cup to the center of the display's top edge, as close to the edge as possible.
Insert an opening pick in the earpiece speaker cutout on the top edge of the display.
Pull up on the suction cup with strong, steady force.
Angle the opening pick to about 30 degrees and push it towards the center of the phone until it slides under the display.
Slide the opening pick to the top right corner of the display.
Pull the the display up and towards the bottom of the phone, making sure to gently thread the display cable through its slot.
Remove the display.
Remove the old adhesive with tweezers or your fingers and clean the frame with isopropyl alcohol (>90%) and a micro-fiber cloth.
Apply new adhesive where the old adhesive was.
Thread the display cable through its slot in the frame.
Press down firmly around the perimeter of the replacement display to secure it to the frame.
To reassemble your device, follow the instructions in reverse order.
Un comentario
Please mention that you need adhesive at the beginning of the guide
