Saltar al contenido principal
Motorola Edge 5G UW (2022) Display Replacement
Qué necesitas
  1. Motorola Edge 5G UW (2022) Display Replacement, Heat the left edge: paso 1, imagen 1 de 1
    • Completely power off your phone before you begin.
    • Heat an iOpener and apply it to the back cover's left edge for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the back cover and internal battery are both susceptible to heat damage.
  2. Motorola Edge 5G UW (2022) Display Replacement, Separate the left adhesive: paso 2, imagen 1 de 3 Motorola Edge 5G UW (2022) Display Replacement, Separate the left adhesive: paso 2, imagen 2 de 3 Motorola Edge 5G UW (2022) Display Replacement, Separate the left adhesive: paso 2, imagen 3 de 3
    • Apply a suction cup to the back of the phone, as close to the bottom left corner as possible.
    • Pull up on the suction cup with a strong, steady force to create a gap between the back cover and the midframe on the left edge.
    • Depending on the age of your phone, this may be difficult. If you're having trouble, apply more heat to the edge and try again.
    • Insert an opening pick into the gap.
  3. Motorola Edge 5G UW (2022) Display Replacement, Slice the left adhesive: paso 3, imagen 1 de 2 Motorola Edge 5G UW (2022) Display Replacement, Slice the left adhesive: paso 3, imagen 2 de 2
    • Slide the pick along the left edge of the phone to slice the adhesive securing the back cover to the frame.
    • Leave the pick inserted in the top left corner to prevent the adhesive from resealing.
  4. Motorola Edge 5G UW (2022) Display Replacement, Heat the top edge: paso 4, imagen 1 de 1
    • Apply a heated iOpener to the back cover's top edge for two minutes.
  5. Motorola Edge 5G UW (2022) Display Replacement: paso 5, imagen 1 de 2 Motorola Edge 5G UW (2022) Display Replacement: paso 5, imagen 2 de 2
    • Rotate the pick around the top left corner to slice the adhesive.
  6. Motorola Edge 5G UW (2022) Display Replacement: paso 6, imagen 1 de 2 Motorola Edge 5G UW (2022) Display Replacement: paso 6, imagen 2 de 2
    • Slide the pick along the top edge to slice the adhesive.
    • Leave the opening pick inserted in the top right corner to prevent the adhesive from resealing.
  7. Motorola Edge 5G UW (2022) Display Replacement: paso 7, imagen 1 de 1
    • Apply a heated iOpener to the back cover's right edge for two minutes.
  8. Motorola Edge 5G UW (2022) Display Replacement: paso 8, imagen 1 de 2 Motorola Edge 5G UW (2022) Display Replacement: paso 8, imagen 2 de 2
    • Rotate the pick around the top right corner to slice the adhesive.
  9. Motorola Edge 5G UW (2022) Display Replacement: paso 9, imagen 1 de 2 Motorola Edge 5G UW (2022) Display Replacement: paso 9, imagen 2 de 2
    • Slide the pick along the right edge to slice the adhesive.
    • Leave the pick inserted in the bottom right corner to prevent the adhesive from resealing.
  10. Motorola Edge 5G UW (2022) Display Replacement: paso 10, imagen 1 de 1
    • Apply a heated iOpener to the back cover's bottom edge for two minutes.
  11. Motorola Edge 5G UW (2022) Display Replacement: paso 11, imagen 1 de 2 Motorola Edge 5G UW (2022) Display Replacement: paso 11, imagen 2 de 2
    • Rotate the pick around the bottom right corner to slice the adhesive.
  12. Motorola Edge 5G UW (2022) Display Replacement: paso 12, imagen 1 de 2 Motorola Edge 5G UW (2022) Display Replacement: paso 12, imagen 2 de 2
    • Slide the pick along the bottom edge to slice the adhesive.
  13. Motorola Edge 5G UW (2022) Display Replacement, Heat the camera adhesive: paso 13, imagen 1 de 2 Motorola Edge 5G UW (2022) Display Replacement, Heat the camera adhesive: paso 13, imagen 2 de 2
    • There's a significant amount of adhesive to the right of the cameras that secures the back cover to the motherboard cover.
    • Apply a heated iOpener to the right of the cameras for two minutes.
  14. Motorola Edge 5G UW (2022) Display Replacement, Slice the adhesive around the camera: paso 14, imagen 1 de 2 Motorola Edge 5G UW (2022) Display Replacement, Slice the adhesive around the camera: paso 14, imagen 2 de 2
    • Insert an opening pick between the back cover and motherboard cover on the top right edge.
    • Gently pull up on the back cover while sliding the opening pick back and forth along the right side of the cameras to slice the adhesive.
    • The back cover should detach from the phone at this point.
  15. Motorola Edge 5G UW (2022) Display Replacement, Remove the back cover: paso 15, imagen 1 de 2 Motorola Edge 5G UW (2022) Display Replacement, Remove the back cover: paso 15, imagen 2 de 2
    • Lift the back cover from the phone and remove it.
    • If the back cover is still stuck to the midframe, slide an opening pick around the edges of the phone until the cover separates completely.
    • During reassembly:
    • This is a good point to test your phone's functionality before sealing it up. Use this guide to run a hardware test. Be sure to power your phone back down completely before you continue working.
    • Follow this guide to replace the back cover adhesive.
  16. Motorola Edge 5G UW (2022) Display Replacement, Unfasten the motherboard cover: paso 16, imagen 1 de 2 Motorola Edge 5G UW (2022) Display Replacement, Unfasten the motherboard cover: paso 16, imagen 2 de 2
    • Use a Phillips screwdriver to remove the 13 4 mm screws securing the motherboard cover.
  17. Motorola Edge 5G UW (2022) Display Replacement, Release the motherboard cover clips: paso 17, imagen 1 de 2 Motorola Edge 5G UW (2022) Display Replacement, Release the motherboard cover clips: paso 17, imagen 2 de 2
    • Insert a spudger between the motherboard cover and midframe on the top right edge of the phone.
    • Pry up with the spudger to release the clips securing the motherboard cover.
    • During reassembly, press down around the perimeter of the motherboard cover to engage the clips.
  18. Motorola Edge 5G UW (2022) Display Replacement, Remove the motherboard cover: paso 18, imagen 1 de 3 Motorola Edge 5G UW (2022) Display Replacement, Remove the motherboard cover: paso 18, imagen 2 de 3 Motorola Edge 5G UW (2022) Display Replacement, Remove the motherboard cover: paso 18, imagen 3 de 3
    • Gently pull the motherboard cover up and away from the phone and remove it.
    • Don't pull quickly or forcefully, as the heat spreader very loosely secures the motherboard cover to the battery.
  19. Motorola Edge 5G UW (2022) Display Replacement, Disconnect the battery: paso 19, imagen 1 de 2 Motorola Edge 5G UW (2022) Display Replacement, Disconnect the battery: paso 19, imagen 2 de 2
    • Use the pointed end of a spudger to pry up and disconnect the battery's press connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  20. Motorola Edge 5G UW (2022) Display Replacement, Detach the daughterboard heat spreader: paso 20, imagen 1 de 2 Motorola Edge 5G UW (2022) Display Replacement, Detach the daughterboard heat spreader: paso 20, imagen 2 de 2
    • Insert the pointed end of a spudger under the heat spreader between the battery and daughterboard.
    • Gently left up and towards the bottom of the phone to detach the heat spreader.
  21. Motorola Edge 5G UW (2022) Display Replacement, Apply isopropyl alcohol: paso 21, imagen 1 de 2 Motorola Edge 5G UW (2022) Display Replacement, Apply isopropyl alcohol: paso 21, imagen 2 de 2
    • Apply a few drops of high-concentration (90% or higher) isopropyl alcohol to the gaps along the battery's edges.
    • Tilt the device as you apply alcohol to help it flow under the battery.
    • Wait one minute to allow the isopropyl alcohol to penetrate the adhesive.
    • Only apply a few drops initially and apply more as necessary. If you apply too much alcohol, it may overflow onto the motherboard and daughterboard.
  22. Motorola Edge 5G UW (2022) Display Replacement, Separate the battery's adhesive: paso 22, imagen 1 de 3 Motorola Edge 5G UW (2022) Display Replacement, Separate the battery's adhesive: paso 22, imagen 2 de 3 Motorola Edge 5G UW (2022) Display Replacement, Separate the battery's adhesive: paso 22, imagen 3 de 3
    • Take care not to puncture or bend the battery during the removal process—a punctured or bent battery may leak dangerous chemicals or cause a fire.
    • Apply a suction cup to middle of the battery.
    • Pull up on the suction cup with strong, steady force to separate the battery from the frame.
    • If the battery doesn't budge, apply a few more drops of isopropyl alcohol, wait one minute, and try again.
    • Insert an opening pick into the gap between the battery and the frame.
    • Continue to pull up on the suction cup with a strong, steady force while sliding the opening pick back and forth to slice the adhesive.
    • Continue this process until the battery separates from the frame, applying a few drops of alcohol as necessary.
  23. Motorola Edge 5G UW (2022) Display Replacement, Remove the battery: paso 23, imagen 1 de 2 Motorola Edge 5G UW (2022) Display Replacement, Remove the battery: paso 23, imagen 2 de 2
    • Remove the battery from the midframe.
    • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
    • Follow this guide to install new battery adhesive.
  24. Motorola Edge 5G UW (2022) Display Replacement, Transfer the battery's foam strip: paso 24, imagen 1 de 3 Motorola Edge 5G UW (2022) Display Replacement, Transfer the battery's foam strip: paso 24, imagen 2 de 3 Motorola Edge 5G UW (2022) Display Replacement, Transfer the battery's foam strip: paso 24, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Use tweezers or your fingers to remove the foam strip from the battery's bottom edge.
    • Before installing your new battery, apply the foam strip to its bottom edge.
  25. Motorola Edge 5G UW (2022) Display Replacement, Place the back cover back on: paso 25, imagen 1 de 2 Motorola Edge 5G UW (2022) Display Replacement, Place the back cover back on: paso 25, imagen 2 de 2
    • Before continuing your repair, place the back cover back on the frame to protect the cameras and motherboard.
  26. Motorola Edge 5G UW (2022) Display Replacement, Loosen the display adhesive: paso 26, imagen 1 de 1
    • Flip your phone over to access the display.
    • Apply a heated iOpener to the display for at least five minutes to loosen the adhesive underneath.
  27. Motorola Edge 5G UW (2022) Display Replacement, Insert an opening pick: paso 27, imagen 1 de 3 Motorola Edge 5G UW (2022) Display Replacement, Insert an opening pick: paso 27, imagen 2 de 3 Motorola Edge 5G UW (2022) Display Replacement, Insert an opening pick: paso 27, imagen 3 de 3
    • Once the display is hot to the touch, apply a suction handle to the top of the display, as close to the edge as possible.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction handle. If all else fails, you can superglue the suction cup to the display.
    • Insert an opening pick in the small gap between the display and the frame, near the front camera.
    • Pull up on the suction handle with a strong, steady force while pushing in and down on the pick until the pick slides under the display.
    • The display adhesive is very strong, so this may take multiple attempts. If you're having trouble, reheat the display and try again.
    • Slide the pick to the top right corner of the display and leave it inserted to prevent the adhesive from resealing.
  28. Motorola Edge 5G UW (2022) Display Replacement, Slice the right adhesive: paso 28, imagen 1 de 2 Motorola Edge 5G UW (2022) Display Replacement, Slice the right adhesive: paso 28, imagen 2 de 2
    • When sliding the pick near the bottom third of the phone, don't insert the pick more than 6 mm to avoid damaging the heat spreader.
    • Insert a second opening pick near the top right corner and slide it along the right edge to slice the adhesive.
  29. Motorola Edge 5G UW (2022) Display Replacement: paso 29, imagen 1 de 2 Motorola Edge 5G UW (2022) Display Replacement: paso 29, imagen 2 de 2
    • Don't insert the pick more than 3 mm to avoid damaging the heat spreader.
    • Insert a third opening pick near the bottom right corner and slide it along the bottom edge to slice the adhesive.
    • Leave the pick inserted in the bottom left corner to prevent the adhesive from resealing.
  30. Motorola Edge 5G UW (2022) Display Replacement: paso 30, imagen 1 de 2 Motorola Edge 5G UW (2022) Display Replacement: paso 30, imagen 2 de 2
    • Don't insert the pick more than 2 mm to avoid damaging the heat spreader.
    • Insert a forth pick near the bottom left corner and slide it along the left edge to slice the adhesive.
    • The screen should be detached at this point.
  31. Motorola Edge 5G UW (2022) Display Replacement: paso 31, imagen 1 de 2 Motorola Edge 5G UW (2022) Display Replacement: paso 31, imagen 2 de 2
    • Flip your phone over to access the back cover.
    • Remove the opening picks and back cover from the phone.
  32. Motorola Edge 5G UW (2022) Display Replacement: paso 32, imagen 1 de 2 Motorola Edge 5G UW (2022) Display Replacement: paso 32, imagen 2 de 2
    • Use the pointed end of a spudger to pry up and disconnect the display cable's press connector.
  33. Motorola Edge 5G UW (2022) Display Replacement: paso 33, imagen 1 de 2 Motorola Edge 5G UW (2022) Display Replacement: paso 33, imagen 2 de 2
    Comprar
    • Use tweezers to grip the display cable just below the press connector.
    • Gently pull the display cable towards the bottom of the phone to separate its adhesive.
  34. Motorola Edge 5G UW (2022) Display Replacement, Remove the display: paso 34, imagen 1 de 3 Motorola Edge 5G UW (2022) Display Replacement, Remove the display: paso 34, imagen 2 de 3 Motorola Edge 5G UW (2022) Display Replacement, Remove the display: paso 34, imagen 3 de 3
    • The display may have lightly readhered to the frame during the last few steps. If it has, use an opening pick to detach the display from the frame before continuing.
    • Before removing the display, make sure that the display's ribbon cable is completely detached from the adhesive on the midframe.
    • Gently pull up on the display and thread the ribbon cable through the hole in midframe to remove the display.
  35. Motorola Edge 5G UW (2022) Display Replacement: paso 35, imagen 1 de 1
    • During reassembly, apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%) and a micro-fiber cloth.
    • Follow this guide if you're using a precut adhesive card.
Conclusión
Compare your new replacement part to the original part—be sure to transfer remaining components and remove adhesive backings from the new part before installing.
To reassemble your device, follow the instructions in reverse order.
Una persona más ha completado esta guía.
Spencer Day
Miembro Desde 09/14/22
58,680 Reputación
430 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
137 Miembros
17,525 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 17
Ultimos 30 días: 66
Todo El Tiempo: 774
